joel_brown Posted October 11, 2021 Share Posted October 11, 2021 I wanted to download and use the PODGO Edit before I bought a PODGO just to see what it's capabilities are. I've owned several Line6 products in the past and have done this to see if it's meets my needs. However, the PODGO Edit doesn't let you see anything unless it has a PODGO connected - unless I'm not doing something right ? Is this how it's supposed to work ? I want to make sure I can run the PODGO in stereo and delay the left channel by 20ms. This give me the stereo effect I've used for years. Link to comment Share on other sites More sharing options...
silverhead Posted October 11, 2021 Share Posted October 11, 2021 Yes, what you are seeing is the way it works. The POD Go must be connected for POD Go Edit to work. Link to comment Share on other sites More sharing options...
grdGo33 Posted October 11, 2021 Share Posted October 11, 2021 3 hours ago, joel_brown said: I want to make sure I can run the PODGO in stereo and delay the left channel by 20ms. This give me the stereo effect I've used for years. About PG Edit, you can check some sample videos about pod go edit, there's some from L6 and a lot of random people making Pod Go videos. For the 20ms stereo delay, I don't think there's a built-in feature that does. PGO has a lot of stereo delays and effects though, so you'll definitely be able to achieve the effect, but not with a 'free' built-in setting; you would have to use one of the 4 dynamic effects block. Unless I'm wrong and someone will correct me :o) Link to comment Share on other sites More sharing options...
joel_brown Posted October 12, 2021 Author Share Posted October 12, 2021 For me to get the effect I'm looking for I need to put a 20ms delay on the left channel and leave the right channel alone. From what I can tell by watching videos and reading manuals, it may possible to do this by placing a stereo delay after the amp/cab that ONLY does a 20ms delay on the left set to full wet and on the right have it set to nothing and full dry. Then I can add other effects before and after the this, making sure they maintain stereo and I'm good to go. Can anyone confirm this for me please ? Link to comment Share on other sites More sharing options...
skryptus Posted October 12, 2021 Share Posted October 12, 2021 There's no multiple paths on the POD Go, so I don't think that's something you're able to do. The best you could do, like @grdGo33 said, is use a stereo delay, like the Dual or the Ping Pong, and adjust it so it gets the effect you want. It's possible that, if you set the Mix so you only hear the delay and not the original signal, but you'd have to try (or ask someone here to try - my POD Go is currently in the shop, so I can't help you there). Link to comment Share on other sites More sharing options...
joel_brown Posted November 9, 2021 Author Share Posted November 9, 2021 I know these forums are mostly supported by other users/customers and I want to thank them for their answers. However, I can't find or get a definitive answer to my question. As soon as I do I will buy the unit. Although the longer I wait the more I look at competitors products, such as Headrush. I wish Line6 had a manual that said more than how to turn the product on and what the effect names were. Or had the Edit software where you could test drive the product before buying it, like they did for the PODHDs. Link to comment Share on other sites More sharing options...
usedbyanr Posted November 9, 2021 Share Posted November 9, 2021 I'm relatively new to guitar but I'm pretty sure the image below is exactly what you are asking about. A 20 ms delay is too short for me to perceive but bumping it up seems to do what you want. I hope that helps. 2 Link to comment Share on other sites More sharing options...
joel_brown Posted November 13, 2021 Author Share Posted November 13, 2021 Thank you. From the image you posted it looks like it will do what I want. You should be able to hear a noticeable difference using this effect when the PODGO is sending both channels back to the mixer and it's hard panned, even at 20ms. Link to comment Share on other sites More sharing options...
usedbyanr Posted November 15, 2021 Share Posted November 15, 2021 On 11/13/2021 at 12:28 PM, joel_brown said: Thank you. From the image you posted it looks like it will do what I want. You should be able to hear a noticeable difference using this effect when the PODGO is sending both channels back to the mixer and it's hard panned, even at 20ms. Maybe it's just my ears but I had AKG K240 headphones on when I posted this and the most I can hear is a slight almost imperceptible sound gap in the left ear at that delay. Link to comment Share on other sites More sharing options...
