sgrain Posted October 12, 2021 Share Posted October 12, 2021 I there Forum , i need to boost the sound for solos ( just increase the volume with no sound changing)for live gigs , everytime i use a boost it changes the sound . Regards Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 12, 2021 Share Posted October 12, 2021 Place a Gain Block at the end of the signal chain. Assigns it's LEVEL to Snapshots. Or Assign the Output Block Level to Snapshots. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted October 12, 2021 Share Posted October 12, 2021 Or just boost using the amp block's 'Chanel volume' parameter... for the 2 or 3 dB boost you'll need for leads, it won't affect your tone. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted October 12, 2021 Share Posted October 12, 2021 If you have a free block left, insert a boost at an appropriate position and control its bypass status. IMO that's a lot easier than assigning different levels. Plus. you can easier adjust it patch-wide. If you control the level via snapshots, you'd have to readjust things for each snapshot. Personally, I'm using a simple EQ for these tasks (allows me to also slightly pronounce the mids, which I usually like) and I place it behind any amp stuff and before any delays and reverbs so overlapping tails don't get boosted/cut when switching snapshots. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 12, 2021 Share Posted October 12, 2021 The difference between using a BOOST vs a GAIN block is that NONE of the boosts are truly "clean", they all affect the overall tone in one way or another. The difference between simply using the block's bypass vs level is that, depending upon what the Snapshot does, you may WANT the added level of fine-tuning that using the block's level allows. This: 27 minutes ago, SaschaFranck said: I place it behind any amp stuff and before any delays and reverbs so overlapping tails don't get boosted/cut when switching snapshots. is a good thing to consider, regardless which method you choose to use. Also, using an EQ, a traditional method going back to analog pedal boards, allows you to (as @SaschaFranckmentioned) slightly boost the mids to help your leads cut through. Going back to using a boost, you may find one that does this naturally, but using an EQ gives you more fine-tuning options. As with everything Helix, lots of ways to skin the cat. Quote Link to comment Share on other sites More sharing options...
MGW-Alberta Posted October 12, 2021 Share Posted October 12, 2021 I typically place a 10 band EQ last in the chain just before the output. That's in addition to everything else, including another earlier EQ, if there is one. I use that last EQ to customize each snapshot individually. Sometimes one of my snaps will use a different OD/Dist block that needs a different output EQ to compensate and sometimes I use it to adjust overall volume for that snap. I find a variety of uses for a final output EQ and it sounds like it would be a great idea for you as well. Quote Link to comment Share on other sites More sharing options...
theElevators Posted October 12, 2021 Share Posted October 12, 2021 To change the sound volume, you can simply click on the output parameter of the preset, assign it to snapshots and change them as you need. I only used this in one preset when stereo delay sound was not loud enough. So in my example, one of the snapshots is using the volume adjustment. My main method to make solos pop out is to boost 2K frequency up 10 db right before the amp block. I add an EQ block. It sounds crazy, but it works for me. I have been using this method with real physical amplifiers. This cleans up the sound, makes it more piercing. If you want to hear how it works for me, here's a recording of my recent show. At 2:35 I start playing my lead. Quote Link to comment Share on other sites More sharing options...
