humanclay212 Posted February 19, 2022 Share Posted February 19, 2022 Something weird has happen to my HX Stomp... all of a sudden, it will only power up with 19v of power. The power supply that comes with it will no longer work. I have tried various 9v power supplies (all center negative) 3-5A max output. I have tried 12v... nothing, 15v... nothing 19v... powers up! Anybody seen this before? 2 Quote Link to comment Share on other sites More sharing options...
bassbene Posted February 19, 2022 Share Posted February 19, 2022 Quite an interesting procedure to increase the voltage... when would you have stopped trying? ;-) Thats definately hardware failure - not sure about the internal operation voltages used in the Stomp. Sounds like something is broken in there. Something may have increased some resistence significantly or some internal voltage regulation is broken... Hard to claim warranty now after you operated with more than twice the demanded supply voltage.. 1 Quote Link to comment Share on other sites More sharing options...
PierM Posted February 19, 2022 Share Posted February 19, 2022 Open a support ticket, but at this point I believe the fix will be at your own expense. It's of course an hardware failure, which you probably make it worse raising voltages by more than 100%... 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted February 19, 2022 Share Posted February 19, 2022 I don't want to pile on, but doubling the voltage was a huge mistake. Send it in for repair... and get your credit card ready for payment. I'll be very surprised if they fix it under warranty... even if the initial fault might have been. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted February 19, 2022 Share Posted February 19, 2022 8 hours ago, humanclay212 said: Something weird has happen to my HX Stomp... Yep… you fried it. Ouch! Quote Link to comment Share on other sites More sharing options...
humanclay212 Posted February 19, 2022 Author Share Posted February 19, 2022 I realized that 19v powered up the hx stomp by accident. As I was trying my different 9v power supplies thinking my hx stomp power supply no longer worked, I accidentally plugged in a 19v ( thinking it was a 9v) all of the sudden it powered up. It works without any issues, as to how long it will continue to stay that way will remain to be seen although i have been usingit this way for about 4 months now. Also, I only tried the other voltages to see if it worked at a lower voltage but it didn't. Anyhow, I appreciate everyone's taking the time to chime in on this. I think it's weird and I don't know how it got this way in the first place but somethings are too remain a mystery :) 1 Quote Link to comment Share on other sites More sharing options...
PierM Posted February 19, 2022 Share Posted February 19, 2022 23 minutes ago, humanclay212 said: I realized that 19v powered up the hx stomp by accident. As I was trying my different 9v power supplies thinking my hx stomp power supply no longer worked, I accidentally plugged in a 19v ( thinking it was a 9v) all of the sudden it powered up. It works without any issues, as to how long it will continue to stay that way will remain to be seen although i have been usingit this way for about 4 months now. Also, I only tried the other voltages to see if it worked at a lower voltage but it didn't. Anyhow, I appreciate everyone's taking the time to chime in on this. I think it's weird and I don't know how it got this way in the first place but somethings are too remain a mystery :) Of course it's your stuff and your money, but from an electronic POV, what you are doing it's just prone for an imminent domino of fried components. It's clear there is still some "firewall" that it's preventing those 19V to fully hit the main controllers and boards. Probably there is still some voltage regulator preventing the disaster, just after the component which failed first. Also, the HX Stomp, for its very tight packaging, has a very hot thermal management by default. As soon as those 19V will hit main boards, I'm pretty sure it's gonna bake for good. What Im saying is that, imho, it's better you fix it now, as it could be just a protection in the early stage of AC control, that needs to be fixed. After that, if the main board will be baked later, it's gonna be just an expensive doorstop. :) Anyway, good luck. :) Quote Link to comment Share on other sites More sharing options...
craiganderton Posted February 20, 2022 Share Posted February 20, 2022 I'd stop powering it up, and order an "official" replacement power supply. It's always good practice to have an extra supply around anyway. It would be interesting to measure the actual voltage going into your HX, maybe the power supply has lousy voltage regulation, and under load it's feeding in more like 10-12V. Quote Link to comment Share on other sites More sharing options...
humanclay212 Posted February 25, 2022 Author Share Posted February 25, 2022 On 2/19/2022 at 9:24 PM, craiganderton said: I'd stop powering it up, and order an "official" replacement power supply. It's always good practice to have an extra supply around anyway. It would be interesting to measure the actual voltage going into your HX, maybe the power supply has lousy voltage regulation, and under load it's feeding in more like 10-12V. The official hx power supply works fine just doesn't power up my hx stomp anymore. The actual voltage going currently into the hx stomp is 19v. It's the only voltage that will power it up other than 18v anything under 18v won't work. Currently looking into sending it in for repair. Quote Link to comment Share on other sites More sharing options...
craiganderton Posted February 27, 2022 Share Posted February 27, 2022 On 2/25/2022 at 3:31 PM, humanclay212 said: The official hx power supply works fine just doesn't power up my hx stomp anymore. Oh, okay. I misinterpreted "The power supply that comes with it will no longer work." as the supply itself was the problem. It will be interesting to see how this resolves, and what the problem actually is. If it happened to you, it could happen to someone else. Quote Link to comment Share on other sites More sharing options...
zachselindh Posted December 2, 2023 Share Posted December 2, 2023 @humanclay212Did you ever get your Stomp repaired? I made a mistake wiring my pedalboard's power and ended up in the same situation as you; the Stomp would only run at 18v. Can you describe what happened with your repair, if you got it done? Quote Link to comment Share on other sites More sharing options...
humanclay212 Posted July 22 Author Share Posted July 22 Justin in case anyone is curious... LOL, have been running the HX Stomp on 18V for the past 4-5 yrs without any issues whatsoever... still running strong! In fact, I had totally forgot that I was even running it on 18V since it's been so long. Anyhow, just thought I'd update this years later... Thanks! Quote Link to comment Share on other sites More sharing options...
