Tempurr Posted March 23, 2022 Share Posted March 23, 2022 I own a Helix floor model and I am trying to hook it up in such a way that I can listen to spotify/yt on my headset (Bluetooth) and play along with my helix, I read the user manual and I believe I have the correct signal path. But I cant for the life of me get any audio to come from my pc. I am using USB audio so I just have that cable going into the pc and my guitar i tried going into "guitar in" and "mono/left" but heard nothing from either input. I plugged it into some monitors and everything was working fine where the Helix is concerned. I also noticed when I selected helix as my input I have signal but still no audio. I tried swapping my USB in 1/2 to 1/4 but still nothing. What am I missing? (I'm new to this so I apologize if the answer is obvious.) Thanks in advance for any help I appreciate it. Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 23, 2022 Share Posted March 23, 2022 The Helix becomes your audio interface, so it will stream audio to and from your computer. If you’re using Bluetooth headphones paired with your computer, those won’t stream audio from the Helix, as they’re a separate interface. You need to have headphones or speakers connected to the Helix to hear the audio from. You’ll be able to stream audio back from your computer to the Helix, so you’ll be able to play along with Spotify, but you just won’t be able to use Bluetooth headphones. 2 Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted March 23, 2022 Share Posted March 23, 2022 And with the inherent latency that many Bluetooth devices have, you don't want to go that route anyway. It's fine for passive music listening, but when playing an instrument in real time, no bueno... Quote Link to comment Share on other sites More sharing options...
brue58ski Posted March 23, 2022 Share Posted March 23, 2022 It sounds like you may have but make sure the output is set to multiple or USB 1/2. Quote Link to comment Share on other sites More sharing options...
Tempurr Posted March 23, 2022 Author Share Posted March 23, 2022 On 3/23/2022 at 5:07 AM, phil_m said: The Helix becomes your audio interface, so it will stream audio to and from your computer. If you’re using Bluetooth headphones paired with your computer, those won’t stream audio from the Helix, as they’re a separate interface. You need to have headphones or speakers connected to the Helix to hear the audio from. You’ll be able to stream audio back from your computer to the Helix, so you’ll be able to play along with Spotify, but you just won’t be able to use Bluetooth headphones. Yep that was it, Bluetooth doesnt work. thank you so much for the help. Quote Link to comment Share on other sites More sharing options...
