joesnewmatch Posted April 18, 2022 Share Posted April 18, 2022 I haven't updated in a while and finally got some time to do it, so I did a backup like always, updated Helix Editor, first, and then did the Firmware update. Everything seems to have worked fine. However, when I went to backup my user presets, I couldn't do it. I can find the folders on my computer, with the backup folder, but the actual backup is grayed-out, and not clickable. I should mention that I am running macOS Monterey Version 12.3.1. Wondering if this is the problem. Any thoughts would be greatly appreciated. I've got 4 years or so of presets I rely on and would have to start over at this point. Thanks. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 18, 2022 Share Posted April 18, 2022 On 4/18/2022 at 2:57 PM, joesnewmatch said: I haven't updated in a while and finally got some time to do it, so I did a backup like always, updated Helix Editor, first, and then did the Firmware update. Everything seems to have worked fine. However, when I went to backup my user presets, I couldn't do it. I can find the folders on my computer, with the backup folder, but the actual backup is grayed-out, and not clickable. I should mention that I am running macOS Monterey Version 12.3.1. Wondering if this is the problem. Any thoughts would be greatly appreciated. I've got 4 years or so of presets I rely on and would have to start over at this point. Thanks. Hi, When you made the "Backup" before installing the FW update, HX Edit by default would place it on your Mac in "Documents/Line6/Tones/Backups" and the file would be named and dated to suit your hardware and tagged as a .hxb file. There should be previous backup files available to restore if you have been making incremental backups with earlier updates. Check for them under the dropdown option on the restore window. To restore the backup you should select "Restore From Backup..." found under the "File" dropdown menu on your Mac. This should automatically point you to where the file was saved. Then choose the Backup items that you wish to restore. If that is not happening, then you could try to "Extract Files From Backup" - also under the Mac's File menu. Using extract should pull out and retrieve any, or all, the files from the backup bundle. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
joesnewmatch Posted April 18, 2022 Author Share Posted April 18, 2022 I can see all of my .hxb files, but I cannot click on them in order to import them into my User Presets. When I also try to use a Restore option from the menu, I see a window showing the Documents/Line6/Tones/Helix/Backups, but it says "no compatible backup files in selection folder -- even though I see my backups there. The .hxb files are grayed out. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 18, 2022 Share Posted April 18, 2022 I'm not a Mac person, but on Windows I would say this could be a permissions problem. Check for any folder permissions settings. 2 Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 18, 2022 Share Posted April 18, 2022 Are you signed into your Line 6 account in HX Edit? Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 18, 2022 Share Posted April 18, 2022 On 4/18/2022 at 5:55 PM, joesnewmatch said: The .hxb files are grayed out. This may sound obvious, but please ensure that the version of HX Edit you are using is 3.15. It is not unknown for some Mac users to have an alias back to an earlier version still lurking on their computer. If it really is HX Edit 3.15 then possibly, as noted by “silverhead” above, you need to ensure that your permissions are set correctly for the folder where the .hxb files are (Mac security as started to become a total PITA). You could also try making a copy of the .hxb files to another area of the Mac (Desktop) where you can access them, then navigate to that location from the HX Edit “Restore From Backup…” window. Remember - always work on a copy. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 18, 2022 Share Posted April 18, 2022 Have you done the factory reset after updating the firmware? How to Factory Reset a Helix Family Device | Sweetwater 1 Quote Link to comment Share on other sites More sharing options...
joesnewmatch Posted April 18, 2022 Author Share Posted April 18, 2022 Finally fixed it. I tried cutting and pasting. Then I "extracted" the content. Then, I physically dragged and dropped into user presets. That finally worked. Appreciate all the feedback. Really, thank you all. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 18, 2022 Share Posted April 18, 2022 On 4/18/2022 at 11:12 PM, joesnewmatch said: Finally fixed it. I tried cutting and pasting. Then I "extracted" the content. Then, I physically dragged and dropped into user presets. That finally worked. Appreciate all the feedback. Really, thank you all. Good to know that you got there in the end - remember “Fail Safe” - always have back up of your backup! 1 1 Quote Link to comment Share on other sites More sharing options...
ebeaty Posted November 4, 2022 Share Posted November 4, 2022 (edited) Please help. I'm having this same issue but with the new 3.50 update. My backup file is grayed out when I use HX Edit 3.50. (See attached screenshot.) When I right-click, there's no "Show contents" available for me to access any of my preset files, Global settings, etc. And when I use "Extract Files from Backup" it shows a grayed out backup as well. Never ran into this problem before and don't want to have to manually start all over or drag and drop much older setlist files. Important Update: Hang on, I figured it out totally by accident. There's an "Open" button on the backup/extract dialog box I accidentally clicked and it restored properly. The key is to select the correct folder and click open. You don't have to select the file itself. When you select the folder and click Open, Helix LT automatically recognizes the backup file in that folder and loads it appropriately. I think this needs to be explained for future updates or as a rule in general somewhere in the manual or on the latest release notes each time as part of the backup steps. Edited November 4, 2022 by ebeaty Found an accidental solution Quote Link to comment Share on other sites More sharing options...
HitmanVinnie Posted November 5, 2022 Share Posted November 5, 2022 Thanks, this worked... In the Quality Assurance world, the term "WORKSFORME" is appropriate here. After enduring nonsense from a Line 6 "Expert" who knows nada about QA and security I found this thread... Experts = Knows nothing, so send youtube video as fact... Quote Link to comment Share on other sites More sharing options...
robsas Posted June 16, 2023 Share Posted June 16, 2023 Well this is most interesting. I'm running a mac and Monterey.. A few months ago I did a successful backup and restored onto a second machine with no issues. Now, I cant do diddly squat! All my full backups do not show as an .hbx file. They show as a document and therefore are totally useless.. Presets are fine but I loaded one and its snapshots didnt arrive with the preset. Ideas please.... even L6 are puzzled! Quote Link to comment Share on other sites More sharing options...
loskalakos Posted November 28, 2024 Share Posted November 28, 2024 On 4/18/2022 at 6:55 PM, joesnewmatch said: I can see all of my .hxb files, but I cannot click on them in order to import them into my User Presets. When I also try to use a Restore option from the menu, I see a window showing the Documents/Line6/Tones/Helix/Backups, but it says "no compatible backup files in selection folder -- even though I see my backups there. The .hxb files are grayed out. you have to go to FILES on the HX stomp edit app and from there you can do the backup. Quote Link to comment Share on other sites More sharing options...
