ReeV0 Posted June 6, 2022 Share Posted June 6, 2022 Hi all, I would really like to put this patch in this video onto my Stomp, but it was created for the Helix Rack. I cannot import it using HX Edit as there's not enough DSP on the Stomp. Is there any way I can edit or modify it somehow, to remove some blocks so that it works on the Stomp? Thanks Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 6, 2022 Share Posted June 6, 2022 (edited) On 6/6/2022 at 11:20 PM, ReeV0 said: Hi all, I would really like to put this patch in this video onto my Stomp, but it was created for the Helix Rack. I cannot import it using HX Edit as there's not enough DSP on the Stomp. Is there any way I can edit or modify it somehow, to remove some blocks so that it works on the Stomp? Thanks Hi, Short answer - No. Both of the supplied presets contain dual paths with an amp and cab in each, plus a whole bunch of other dynamics and EQ stuff. My guess is it would be possible to strip out the second path, but it would possibly detrimental to the overall sound, which is what you are chasing. See pic. I’m not in the studio until tomorrow (it’s midnight here), and I haven’t been able to to check out the 2 presets in my Helix to see how much the tone changes when you switch off one path. Although I did discover today in another post on here there is a web site that will allow you to view various Preset files to see how they built. Check it out here (it's where the screen grab above came from): https://hxview.netlify.app Load up the Dingwall.hlx files and view them for yourself, and then if you think you may be able to cope with the single top path, report back and when I get into the studio tomorrow I can strip out the extra blocks. No guarantee that it will be acceptable, but worth a shot. Hope this helps/makes sense. Edited April 11, 2023 by datacommando Removed Attachments 1 Quote Link to comment Share on other sites More sharing options...
benriddell Posted June 6, 2022 Share Posted June 6, 2022 While a very manual approach, the easiest way I've found to take parts of complex presets I like and make a Stomp version is to load the file into this site then flick between the web browser and HX Edit and make the preset https://sensationnel-gerard-26922.herokuapp.com/# You'll get quicker at it the more you do it (or if you're job is to flick between multiple spreadsheets or coding windows it'l be a doddle) Quote Link to comment Share on other sites More sharing options...
ReeV0 Posted June 12, 2022 Author Share Posted June 12, 2022 Thanks all for the great replies! https://dbagchee.github.io/helix-preset-viewer/ https://sensationnel-gerard-26922.herokuapp.com/# https://hxview.netlify.app/ Out of all 3 of these, I found the middle link the easiest to follow. I tried making both paths separately but neither of them sounded anything like the Youtube clip. Never mind! 2 Quote Link to comment Share on other sites More sharing options...
benriddell Posted June 13, 2022 Share Posted June 13, 2022 Looking at the presets in the viewer you're going to be missing the dual amp/cab blend as one is running "dirty" with the drive block and the other is "clean". It's shame you couldn't get something you liked the sound of out of it Quote Link to comment Share on other sites More sharing options...
Fred0caster Posted May 3, 2024 Share Posted May 3, 2024 On 6/12/2022 at 11:59 PM, ReeV0 said: Thanks all for the great replies! https://dbagchee.github.io/helix-preset-viewer/ https://sensationnel-gerard-26922.herokuapp.com/# https://hxview.netlify.app/ Out of all 3 of these, I found the middle link the easiest to follow. Couldn't actually load the middle link? The third one works fine but wanting to try the middle link and it sends me to this page: Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 3, 2024 Share Posted May 3, 2024 On 5/3/2024 at 12:06 PM, Fred0caster said: Couldn't actually load the middle link? The third one works fine but wanting to try the middle link and it sends me to this page[...] Yeraym updated the app and migrated to different hosting service: https://hxview.vercel.app/ Quote Link to comment Share on other sites More sharing options...
