SweetTart61 Posted November 20, 2022 Share Posted November 20, 2022 Hello All. I recently upgraded to 3.5 on my main Win10 laptop. I moved to my backup laptop, HP Envy, on which it worked fine in the past and it won't open. I uninstalled all the Line 6 software and the HX drivers, rebooted, download HX Edit again, rebooted and it still won't open. Click on the executable in Win Start menu and nothing happens at all. Seems like this is the day that all computers hate me, but this just doesn't make sense. I've used the HX on the main laptop with the Stomp off and the Edit app will open and just won't connect to the Stomp, fwiw. Any ideas? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 20, 2022 Share Posted November 20, 2022 If your HXS is at 3.50, make sure your HX Edit is 3.50. Turn the HXS ON. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted November 20, 2022 Share Posted November 20, 2022 @SweetTarty61be sure that all of the Line 6 software is removed from the problematic laptop! You may need to use the Windows Removal Tool, if the Control Panel method fails to accomplish a thorough Uninstall of the Line 6 software. Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 20, 2022 Share Posted November 20, 2022 On 11/20/2022 at 5:15 AM, SweetTarty61 said: Any ideas? Hi, You mentioned that you have moved to a different laptop, which immediately made me think that you may have fallen foul of the dreaded SD Card syndrome. Check this thread - Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
SweetTart61 Posted November 21, 2022 Author Share Posted November 21, 2022 On 11/20/2022 at 12:02 PM, rd2rk said: If your HXS is at 3.50, make sure your HX Edit is 3.50. Turn the HXS ON. HX is at 3.50 and is turned on. I downloaded the 3.50 software from the Line 6 site and installed on troubled laptop. Quote Link to comment Share on other sites More sharing options...
SweetTart61 Posted November 21, 2022 Author Share Posted November 21, 2022 On 11/20/2022 at 3:21 PM, MusicLaw said: @SweetTarty61be sure that all of the Line 6 software is removed from the problematic laptop! You may need to use the Windows Removal Tool, if the Control Panel method fails to accomplish a thorough Uninstall of the Line 6 software. I used the Win uninstall tools to remove the app before reinstalling with a new software download. I will try using Revo Uninstaller to get all the remnants and reinstall again. Quote Link to comment Share on other sites More sharing options...
SweetTart61 Posted November 21, 2022 Author Share Posted November 21, 2022 On 11/20/2022 at 3:55 PM, datacommando said: Hi, You mentioned that you have moved to a different laptop, which immediately made me think that you may have fallen foul of the dreaded SD Card syndrome. Check this thread - Hope this helps/makes sense. The HX Edit software won't open AT ALL. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 21, 2022 Share Posted November 21, 2022 Maybe it's time to reinstall Windows. Sometimes a clean start is what it takes. Don't forget to find and back up anything you don't want to lose. 1 Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted November 21, 2022 Share Posted November 21, 2022 @SweetTart61, before you attempt the far more invasive reinstallation of your entire OS, consider downloading to your local hard drive entirely clean copies of each of the Line 6 software and firmware for your devices (HX Edit, Firmware for each device, Helix Native if you use it, etc.) and using Line 6 Updater ver 1.27 (most recent version released a few weeks ago) to install all the firmware and software from the local copies just downloaded to your hard drive. If still no good, you'll have to consider your OS or Win 10 laptop may be the issue. 2 Quote Link to comment Share on other sites More sharing options...
usedbyanr Posted November 22, 2022 Share Posted November 22, 2022 On 11/21/2022 at 1:23 PM, SweetTart61 said: The HX Edit software won't open AT ALL. If you managed to get to the third page of the link in datacommando's reply, you would have seen my comment. HX Edit appearing not to open is exactly the SD card problem. I'm not saying it's your problem but it sure sounds that way. It was/is a problem for HX Edit, Helix Native and Pod Go Edit. It has to do with reading your hard drive serial number. (It's used as part of the security) The software starts but you never see the interface because it crashes before showing anything. Whoever wrote the serial number code didn't account for the possibility of not having one and ignored the API return code. Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 22, 2022 Share Posted November 22, 2022 On 11/22/2022 at 2:30 PM, usedbyanr said: If you managed to get to the third page of the link in datacommando's reply, you would have seen my comment. Hi, Thanks for clarifying that, as my post must have been linked back to the comment from "CamelotOne", who I believe was the first person to discover that the SD Card was causing the issue. Your link goes straight to your post (Sept 21st 2020) with your explanation and details of how to fix it. Excellent, let's hope it solves it for the OP. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 22, 2022 Share Posted November 22, 2022 There's at least 3 problems here: The Native won't open SD card problem The no SD card but won't open problem - fixed (AFAIK - worked for me) by a recent change on the L6 end The UI glitch - performing certain actions - moving a block, moving a slider on the new Cab Block, maybe others - crashes Reaper The UI glitch was brought up in another thread and I was able to confirm. Hopefully, they opened a support ticket. 1 Quote Link to comment Share on other sites More sharing options...
