altonabeach Posted March 27, 2014 Share Posted March 27, 2014 Hi, I've tried to load m4a files, but stagescape M20d media player recognises only mp3 files, is that so? Regards Altonabeach Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted March 27, 2014 Share Posted March 27, 2014 Yes I believe that's the case. You could try downloading a free app call all2mp3 for mac. And I believe there is an All to MP3 app for windows as well but I don't know if it's free or not. 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 27, 2014 Share Posted March 27, 2014 It can aslo handle WAV filetypes. Here's a snip from the manual: Attach a USB 2.0 hard drive here to record and play back multichannel audio sessions using the M20d’s built-in recording and playbacksoftware. You can also use USB storage to save and recall M20d Presets, or store MP3 and WAV files, which the M20d can play as backing tracks ormusic between sets. 1 Quote Link to comment Share on other sites More sharing options...
altonabeach Posted March 27, 2014 Author Share Posted March 27, 2014 Hi, I've converted all my AIFF files into Wave files using "Smart Converter Pro2" and saved it into a flash drive (USB 30GB stick). Into m20d but still problems with Media player, as I get vthe following message:A PROBLEM WAS ENCOUNTERED IN ATTEMPTING TO PLAY THE SELECTED FILES". SOME HELP WOULD BE APPRECIATED. Thanks Quote Link to comment Share on other sites More sharing options...
altonabeach Posted March 31, 2014 Author Share Posted March 31, 2014 Here I am again. I've done few more tests, and it seems that M20d media player DOES PLAY my mp3, but not the converted Wave files... Shall I convert all the songs to mp3 ? or perharps there's a solution to getb to play my converted wave files... Quote Link to comment Share on other sites More sharing options...
altonabeach Posted March 31, 2014 Author Share Posted March 31, 2014 One more problem: I get a double entry when I add mp3 files to M20d media player Play List Ex : Old time rock & Roll -Old time rock & Roll Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted March 31, 2014 Share Posted March 31, 2014 I remember this problem. I think the answer is here - http://line6.com/support/topic/83-playing-canned-music-from-sd-card/?hl=%2Bmedia+%2Bplayer&do=findComment&comment=295 It's a mac thing I believe. I had the problem, but not anymore. 1 Quote Link to comment Share on other sites More sharing options...
altonabeach Posted April 2, 2014 Author Share Posted April 2, 2014 I'm also trying to retrieve a recording I did with SD card (Its ok on m20d) but the tracks don't show when connected to my computer!!! Quote Link to comment Share on other sites More sharing options...
joecozzi Posted April 6, 2014 Share Posted April 6, 2014 Hi altonabeach, I'm assuming you are trying to edit those tracks using a DAW (recording program). You won't be able to see any tracks when connected to a computer. You have to stream the audio from the M20d into your computer, recording it into your favorite DAW on separate tracks. Only then will you be able to "see" (edit) them. Section 4-8 of the manual explains the process. Also, make sure you have the latest Line 6 driver installed on your computer. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 6, 2014 Share Posted April 6, 2014 I'm also trying to retrieve a recording I did with SD card (Its ok on m20d) but the tracks don't show when connected to my computer!!! Alternately, you can import the tracks from the SD card into your DAW. The tracks/channels recorded by the M20d are stored as individual WAV files on the SD card. Most DAWs support importing WAV files as new audio tracks. Quote Link to comment Share on other sites More sharing options...
GaelW Posted April 27, 2014 Share Posted April 27, 2014 One more problem: I get a double entry when I add mp3 files to M20d media player Play List Ex : Old time rock & Roll -Old time rock & Roll Hi. It´s a problem with Mac invisible files. Install freeware like "CleanMyDrive" from the MacAppStore solve this. Use it to eject your fat formatted SD card or USB drive will clean this files. Quote Link to comment Share on other sites More sharing options...
stormstudios Posted April 28, 2014 Share Posted April 28, 2014 yeah the answer was correctly posted right below it....make sure you actually read the threads. Quote Link to comment Share on other sites More sharing options...
GaelW Posted June 18, 2014 Share Posted June 18, 2014 yeah the answer was correctly posted right below it....make sure you actually read the threads. The answer, but not the solution?! Quote Link to comment Share on other sites More sharing options...
stormstudios Posted June 18, 2014 Share Posted June 18, 2014 Don't be so obtuse and keep bringing up old threads. Digital-sound already posted the answer and the solution. You've obviously missed reading it twice now. Read the threads you post in. I remember this problem. I think the answer is here - http://line6.com/support/topic/83-playing-canned-music-from-sd-card/?hl=%2Bmedia+%2Bplayer&do=findComment&comment=295It's a mac thing I believe. I had the problem, but not anymore. Quote Link to comment Share on other sites More sharing options...
