Custom Footswitch Name
weswagner
I have a patch that contains two amps.  I would like to assign them both to one footswitch and toggle between the two.  Is there a way to name the footswitch in such a way that the name of the amp that is currently on is displayed on the scribble strip?  As of now, I've resorted to putting them on seperate footswitches and just fat footing them to toggle.
The only way to do custom labels, in my head.....would be to use Stomp Mode and assign each amp block to be engaged in a different snapshot.  Snapshot 1 - Amp A, Snapshot 2 - Amp B.
Thus when you use command center to program your 'layout', you would then assign (for example):
Snapshot 1 layout:
Button 7 - Snapshot 2 - Color would follow the Snapshot color you assigned, as well as the name of Snapshot 2 (Amp B)
Snapshot 2 layout:
Button 7 - Snapshot 1 - Color would follow the Snapshot color you assigned, as well as the name of Snapshot 1 (Amp A)
Otherwise, assigning the bypass states to the same button as a stomp button and alternating them would give you an A/B situation, the color/scribble name could not change then as stated above.
