Need help Understanding the .hls file format.
dethioux
Hello,
I am working on a MIDI controller with LED displays and I would like to use a backup file (format .hls) to retrieve the name and footswitch default status (i.e. what FS is on/off for each snapshot when I go to the preset or change snapshot etc). Since I don't change my setlist that frequently I am not trying to read directly from the unit but instead hard code the names and behaviors based on the .hls.
I use a JSON parser to decode the .hls file and see there is a section called footswitch
Here is an example (see full file in attachment)
'footswitch': {'dsp0': {'block0': {'@fs_enabled': True,
                                                          '@fs_index': 5,
                                                          '@fs_label': 'Volume '
        'Pedal',
                                                          '@fs_ledcolor': 65408,
                                                          '@fs_momentary': False,
                                                          '@fs_primary': True},
                                               'block1': =
etc..
Based on that, I originally assumed that each @fs_index would refer to a footswitch with @fs_enable for the status.
However, that doesn't seem to be the case because I have a few setups with @fs_index > 5.
To make things more confusing, I also see some presets without the
'footswitch' blocks though there are setup in the unit.
Has anyone be able to understand how the hsl file work for the foot-switches assignment ? Any guidance on how to interpret the structure of this file ?
Thank you.
Pat.
Test.txt
FYI, the .hls file is used for Setlists, not backup files, and I guess for what you want to achieve, you may be better hacking a preset file.
Presets = .hlx
Set Lists = .hls
Bundles = .hlb
Hope this helps/makes sense.
