serviviente Posted May 16, 2024 Share Posted May 16, 2024 Hello guys. Ive been a HX Stomp user for YEARS, never had a problem. Recently I did the 3.71 update and my stomp has not stopped acting up. It shuts down constantly, when i connect to HX EDit, when i tried to change presets or just by itself. I have tried everything including reseting the unit. Updating the HX edit, downloading the update thru Line 6 updater (not hx edit) while the unit is on "update mode" (page right as you turn on unit) and the unit keeps acting up. I cant use it. It just shuts on/off constantly. I do not know what else to try, i am at my wits end. Any advice will be appreciated... Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 17, 2024 Share Posted May 17, 2024 That is NOT normal. You've tried the usual remedies. Contact support. 1 Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 17, 2024 Share Posted May 17, 2024 On 5/16/2024 at 3:36 PM, serviviente said: Hello guys. Ive been a HX Stomp user for YEARS, never had a problem. Recently I did the 3.71 update and my stomp has not stopped acting up. It shuts down constantly, when i connect to HX EDit, when i tried to change presets or just by itself. I have tried everything including reseting the unit. Updating the HX edit, downloading the update thru Line 6 updater (not hx edit) while the unit is on "update mode" (page right as you turn on unit) and the unit keeps acting up. I cant use it. It just shuts on/off constantly. I do not know what else to try, i am at my wits end. Any advice will be appreciated... If a factory reset didn't solve the problem, then there's really nothing else you can do as an end user...all you can do at this point is open a service ticket and cross your fingers. 1 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 17, 2024 Share Posted May 17, 2024 Avoid using a USB hub and try a different cable and/or USB port. 1 Quote Link to comment Share on other sites More sharing options...
PerS Posted May 18, 2024 Share Posted May 18, 2024 If you haven’t done it, try reinstalling the firmware. When you do so be sure your use a USB port that have power management of the USB-ports turned off. Preferable don’t turn your PC/Mac off at all do not use built in hub And don’t use an external hub (as Schmalle noted) and use a USB cable that you know works (preferably been used before to successfully upgrade your firmware). I would also suggest closing any application that is not needed during the update. After reinstallation reboot your Stomp and do a factory reset of your Stomp, but do not restore your backup. Test the Stomp and see if this might help (I guess that Line6 will ask you to do this if you open a ticket… you will be one step ahead :-). One additional thing, if there is a risk your Internet connection is shaky, make the upgrade locally from a downloaded firmware and do an MD5-checksum test before doing the upgrade, just to be sure the file is not corrupted. You will find the MD5 checksum on the download page after you accept the license agreement. The MD5 utility you will find on the download page and in the center box (- Choose software -) select MD5 Utility and in the third box select your operating system. Hope it’s one step forward… //Per 1 Quote Link to comment Share on other sites More sharing options...
PerS Posted May 28, 2024 Share Posted May 28, 2024 Just to clarify my perhaps not entirely clear description :-) To make the reinstallation you need to set your Helix/Hx in update mode, this is the first check to see how severe the problem is. Check these options, https://helixhelp.com/tips-and-guides/universal/reset-options, depending on your device (turn power off -> hold down correct key combo and turn power back on). If your device can’t get into update mode I think you need to send it to a Line6 service center. If your device is stable in update mode, make the reinstallation by using the Updater software and after firmware reinstallation make a factory reset. Restart you devise and check if its stable in “normal operation”, eg. Add an amp and make some tweaks. If good preside. I made a note not to reinstall your backup. The reason for that is to verify that your unit doesn’t get any crap restored from the old configuration. If your firmware installation and tests worked, you can try to restore you backup and check that the unit still perform. Hope this made it "more clear”… //Per Quote Link to comment Share on other sites More sharing options...
