Stereo effects before split into dual amps, Is it still stereo?
Barbarisch
On 6/7/2024 at 9:44 AM, Schmalle said:
That is a contradiction.
Paths are always stereo; blocks can be mono or stereo.
On 6/7/2024 at 9:29 AM, rd2rk said:
Every path is stereo. When you split a stereo path you get two parallel stereo paths.
If you put an amp in each path you get two parallel mono paths.
Amps are mono blocks. Put an amp in a stereo path you get a mono path.
Stereo block before dual mono paths = stereo at the merge/mix block.
BUT... to keep the stereo effect the panning has to be consistent.
SplitStPost.hlx SplitStPre.hlx
