rofus Posted March 2 Share Posted March 2 Hi I'm trying to assign in Command Center an HX Snapshot command (to two specific snapshots) to FS1 and FS7, but even doing so they keep having their original assignment of up/down instead of what I assigned in Command Center. Why? Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 3 Share Posted March 3 On 3/2/2025 at 11:51 PM, rofus said: Hi I'm trying to assign in Command Center an HX Snapshot command (to two specific snapshots) to FS1 and FS7, but even doing so they keep having their original assignment of up/down instead of what I assigned in Command Center. Why? Hi, Follow Steve’s example in this video. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
enjalt Posted March 3 Share Posted March 3 On 3/3/2025 at 12:51 AM, rofus said: Hi I'm trying to assign in Command Center an HX Snapshot command (to two specific snapshots) to FS1 and FS7, but even doing so they keep having their original assignment of up/down instead of what I assigned in Command Center. Why? I may be wrong but I think it's because you don't use the setting "10 switches" in stomp mode section "Global settings" 1 Quote Link to comment Share on other sites More sharing options...
theElevators Posted March 3 Share Posted March 3 You can change the layout of your Helix, but that only applies to the stomp mode. You can either add individual/multiple effects and assign them to various footswitches, and/or you can assign preset changes/snapshots--the latter can only be done with the Command Center. So in essence, your Helix will have 2 layouts: the regular default one, and another one that you can go into if you press the "mode" button. If you are using Helix LT (which you are), then you cannot repurpose up/down buttons to do anything else, besides up/down. Helix LT allows you to assign things to only 8 footswitches in the stomp view. You can however remove the functionality for up/down buttons to make them do absolutely nothing using a hack--uploading Global Settings with 10-stomp mode enabled from Helix Floor. It's a hack, and not intended functionality. That is something that I personally use, and you can watch this video to see how to do it: https://youtu.be/UTQ8wJaXZnc?si=rZ1xHjcUP0VP1eQ8 To be able to use all 10 footswitches for presets/snapshots/stomps, you need to buy the Helix Floor or Rack. Once you enable "10-button stomp" in Global Settings, then you can assign all 10 buttons as you please. Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 4 Share Posted March 4 On 3/2/2025 at 11:51 PM, rofus said: Why? Oops! Apologies, I misinformed you - your Helix LT does not have the 10 foot-switch option available. Thanks to @theElevators for pointing out the restriction of the capabilities of the LT unit. Quote Link to comment Share on other sites More sharing options...
