PeterJ15 Posted April 19, 2014 Share Posted April 19, 2014 I have a JTV that had some problems when I got it home. Battery life, model selector and first string slipping out of the nut...frequently. I opened a ticket and had to ship it to line 6 for repair. I was told it got a new neck and setup, battery replaced ( although I was told the original was fine?!) and model selector switch fix (was told it was a common issue) When I play my first string even unamplified you can hear a ring or harmonic. When I lay my finger behind the nut ever so gently like I'm trying to create a harmonic it goes away. These are not inexpensive guitars and I continue to read about issues. The features the company advertises are desirable. Obviously many of us have purchased them because of what they promise. I wish the company would make the products they advertise deliver on the promise of function and quality. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted April 19, 2014 Share Posted April 19, 2014 The nut slot for that string may not be just right causing the string to move too much in there. You said the string pops out of the nut. I have a tele that the 1st string popped out on and same kind of weirdness so I redid the slots (after reading up on the subject) and all was good, never popped out again and sounds great. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted April 19, 2014 Share Posted April 19, 2014 I have a JTV that had some problems when I got it home. Battery life, model selector and first string slipping out of the nut...frequently. I opened a ticket and had to ship it to line 6 for repair. I was told it got a new neck and setup, battery replaced ( although I was told the original was fine?!) and model selector switch fix (was told it was a common issue) When I play my first string even unamplified you can hear a ring or harmonic. When I lay my finger behind the nut ever so gently like I'm trying to create a harmonic it goes away. These are not inexpensive guitars and I continue to read about issues. The features the company advertises are desirable. Obviously many of us have purchased them because of what they promise. I wish the company would make the products they advertise deliver on the promise of function and quality. It does sound like a problem with how the nut is slotted. If you don't want to send it back again, any decent luthier should be able to take care of it, and it shouldn't be a million dollar fix. Not sure if it would need a whole new nut or not, but either way it won't be that expensive. You don't say which JTV you have, but if its the 69, then you have replacement neck options too. Mighty Mite, Warmoth...basically anything that will fit a Strat neck pocket should fit nicely on the 69. Obviously that route will cost you more than just dealing with the nut, but it might work for ya. Good luck. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 19, 2014 Share Posted April 19, 2014 I have heard of an improvised solution involving a piece of material placed beneath the strings behind the nut, providing a damping effect. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted April 21, 2014 Share Posted April 21, 2014 Sounds like a bad nut job but you should try putting some damping material on the strings past the nut. I do that on all of my guitars and it keeps those short strings from ringing. Quote Link to comment Share on other sites More sharing options...
badmelonfarmer Posted April 23, 2014 Share Posted April 23, 2014 First string? Do you mean the low E (thickest string) or high E (thinnest string) Reason I ask is there is a thread with with a weird harmonic plink plonk sound on the Low E. I had this on a JTV-59p... Others on the 89 etc Mine is currently back at line 6 being looked at, support ticket suggested a bad piezo. Quote Link to comment Share on other sites More sharing options...
