specktr02 Posted October 24 Share Posted October 24 Anyone of you had experiment this ? Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 24 Share Posted October 24 Does this happen with all presets or only one/some? It sounds like there may be an FX block that you are not aware of. For instance, a Noise Gate block (embedded in the Helix LT Input block) can possibly have that effect. Examine each FX block in the preset(s). Begin by turning each block on/off until you find the one that is causing the effect. Then adjustt the parameter settings for that block to remove the unwanted effect. 1 Quote Link to comment Share on other sites More sharing options...
specktr02 Posted October 25 Author Share Posted October 25 It's happen with all the preset ( factory included ) That never did this before .... yet i have put off the noise gate and the same thing still happen ...it's weird ...maybe it's a bad connection inside in relation with the guitar input ( When i listen the music ( via Cubase , or youtube etc etc the sound is ok ...it's happen only with all of my guitars ) Maybe i have to go at the dealer for a check-up Quote Link to comment Share on other sites More sharing options...
specktr02 Posted October 25 Author Share Posted October 25 About my Helix LT i love it .... it's reliable ...on stage and at home too ( for recording ) it's my best medium between my Mac ,Cubase and my ears ... i wish to fix this soon ...Thank you for your time "Silverhead" Quote Link to comment Share on other sites More sharing options...
Schmalle Posted October 25 Share Posted October 25 Does this occur without connecting to your Mac? Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 25 Share Posted October 25 On 10/25/2025 at 1:44 AM, specktr02 said: It's happen with all the preset ( factory included ) That never did this before .... yet i have put off the noise gate and the same thing still happen ...it's weird ...maybe it's a bad connection inside in relation with the guitar input ( When i listen the music ( via Cubase , or youtube etc etc the sound is ok ...it's happen only with all of my guitars ) Maybe i have to go at the dealer for a check-up Hi, When weird and unexpected things happen the first line of defence is to perform a factory reset: - Helix LT Reset Options Helix Floor/LT Button Combination Description 2 LED light Fun 3 & 4 Test Mode 5 & 6 Global reset 7 & 8 Reset setlists to factory, Keep IRs 8 & 9 Reset setlists to factory, Clear IRs 9 & 10 Reset setlists to factory, Global reset, Clear IRs 10 & 11 Upgrades existing presets to latest format 11 & 12 Clear current preset 5 & 12 Clear setlists, clear IRs, Return system settings to default 6 & 12 Safe boot mode To use Reset Options: Power off the Helix Hold the desired button combination Power on the Helix Release the button combination Please note: Buttons are numbered from top left to bottom right. Note: If this doesn’t clear the problem, it maybe advisable to reinstall the Firmware. You didn’t mention what version you have in your LT, but upgrading to the latest version (3.80) helps to fix various known bugs. Hope this helps/makes sense. 2 Quote Link to comment Share on other sites More sharing options...
PierM Posted October 26 Share Posted October 26 Are you using some external midi controller and maybe getting midi CC loops? 1 Quote Link to comment Share on other sites More sharing options...
specktr02 Posted October 31 Author Share Posted October 31 On 10/25/2025 at 8:50 AM, datacommando said: Hi, When weird and unexpected things happen the first line of defence is to perform a factory reset: - Helix LT Reset Options Helix Floor/LT Button Combination Description 2 LED light Fun 3 & 4 Test Mode 5 & 6 Global reset 7 & 8 Reset setlists to factory, Keep IRs 8 & 9 Reset setlists to factory, Clear IRs 9 & 10 Reset setlists to factory, Global reset, Clear IRs 10 & 11 Upgrades existing presets to latest format 11 & 12 Clear current preset 5 & 12 Clear setlists, clear IRs, Return system settings to default 6 & 12 Safe boot mode To use Reset Options: Power off the Helix Hold the desired button combination Power on the Helix Release the button combination Please note: Buttons are numbered from top left to bottom right. Note: If this doesn’t clear the problem, it maybe advisable to reinstall the Firmware. You didn’t mention what version you have in your LT, but upgrading to the latest version (3.80) helps to fix various known bugs. Hope this helps/makes sense. Thank you Data Commander ( Commando too ) I'd try your advices and taking these on notes too ... Unfortunately it's seem it's a physical issue ... i'll try to put my Helix LT but the near dealer from here in Canada is to far ( I'm in Quebec Canada ) I'm thinking for another option yet ( maybe another gear ...same Brand of course ) I have to see ...thanks a lot for you all ... i update you later on ...soon 1 Quote Link to comment Share on other sites More sharing options...
specktr02 Posted October 31 Author Share Posted October 31 On 10/26/2025 at 12:18 PM, PierM said: Are you using some external midi controller and maybe getting midi CC loops? No ...directly in the box inside a Peavy full lamp 50/50 ,via USB on Mac or Windows , or head phones ...same issue ...no one of these 3 external machines work with my guitars ( I reply to Schmalle too for his question ) Good Night for all of you 1 Quote Link to comment Share on other sites More sharing options...
