anthoninhosantos Posted May 7 Share Posted May 7 Sorry if this was asked before but is there a difference between using a single AMP+CAB block rather than a separate Amp block and Cab block? I'm currently using separate blocks but I want to free up a block to use a mod effect or something. Thanks in advance ! Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 7 Share Posted May 7 Both sound the same. AMP+CAB is convenient (one block only, can be saved and named as Favorite). Two blocks provide options (dual cabs, cab split to FOH etc). 1 Quote Link to comment Share on other sites More sharing options...
surfsup1955 Posted May 26 Share Posted May 26 Some like to load time based effects, gains, etc in between the blocks so separating them allows for that. I've done it and typically like the results when I do. 1 Quote Link to comment Share on other sites More sharing options...
theElevators Posted May 26 Share Posted May 26 I use both. Same identical sound if you use the same settings. amp and cab = amp block + cab block. I figured out that I can run a compressor between the amp and cab, and I do that sometimes. So that's the only time I will use 2 separate blocks, when I need to put something in the middle. The compressor to me is not suitable for every situation. But sometimes it really makes fast playing a lot easier, for all the shreddy solos, or really fast aggressive palm muting. It also makes clean solos sound like they are supposed to--compressed, bold, not whimpy. When placing the compressor there, I always turn down the ripple of my amp, otherwise there's a low frequency hum that appears. However at the same time the compressor adds a certain amount of "harshness" and depending on the signal chain can even make my preset develop certain artifacts, such as pops. So I use this trick sparingly. 1 Quote Link to comment Share on other sites More sharing options...
