Kryz87 Posted September 3 Share Posted September 3 Hi guys! I recently got myself a Stadium Floor - mainly because I wanted to uitlize Showcase. Now here comes the problem: I just can't upload tracks via the Windows app. No matter which of the supported formats I'm trying to use (all in 48kHz@24bit) the app does not accept the files I'm trying to upload. Steps I've taken: - reformatted the stock SD-Card multiple times - changed the SD-Card for SanDisk one, multiple reformats - multiple Factory Resets - trying to run the App as Admin I'm desperately trying to make this work, because Showcase was the reason I chose the Stadium in the first place and without Showcase the unit is a very expensive paperweight for me. Anyone experienced this issue? For the records: App version is 1.3.3, unit is on 1.3.2 greez, Kryz Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 4 Share Posted September 4 Are you sure the files are in WAV format? That’s the only format accepted. Quote Link to comment Share on other sites More sharing options...
jpdennis Posted September 4 Share Posted September 4 @Kryz87 Since I don't have all your connection details I may be repeating what you've already done. I had to use a USB-C to USB-C cable connector from workstation to Helix Stadium XL. I exported my stem files using 44.1 kHz 32 bit for the audio rate and size. Except for the learning curve of specifics on how to consistently order the files and flags the wav files imported perfectly. The Stadium does the conversion to the rate(s) it wants anyway. I know my rates may not be norm but that is what I found and the sound quality was actually pretty good. Dennis Quote Link to comment Share on other sites More sharing options...
christienmeier Posted September 5 Share Posted September 5 Not sure if relevant here, but I recently discovered that Stadium won't accept WAV files with names that include special characters - once removed, they were accepted fine. In my particular case I had parenthesis in the title, e.g., "Music (no vocals).WAV" -> once I renamed to "Music no vocals.WAV" it uploaded no problem. File name constraints aren't listed as a limitation in the online manual, but in my case seem to be one. Quote Link to comment Share on other sites More sharing options...
enjalt Posted September 7 Share Posted September 7 Hi, Did you check the following prequisites: WAV (.wav), AIFF (.aif), FLAC (.flac), or OGG Vorbis (.ogg) Maximum length of 13 minutes play time Sample Rate of 44.1, 48, 88.2, or 96kHz Bit rate of 16, 24, or 32-bit Mono or stereo Quote Link to comment Share on other sites More sharing options...
Ekim_Efendi Posted September 11 Share Posted September 11 For me it works fine and reliable using WLAN, as far as I recall I have tried with USB first but for some reason I changed to WLAN. Maybe I have experienced issues with USB but I cant't remember. BTW: Helix (PC-APP) expects WAV format, other formats are not accepted. Quote Link to comment Share on other sites More sharing options...
Uzka2 Posted October 17 Share Posted October 17 Jou, i tried to solve this problem for ages. I could not drag any of my files on the showcase transferscreen. I found a solution for my self atleast: I moved the files i was transferring on a shorter filepath. Previously my files were in my DAW project folders and the file path was very deep. I moved my files to just D:\Music and tried draggin from there and vóila it worked for some reason. I did not test this further as it works but it seems like there could be a maximum character value for how long filepaths the software can read from your devices harddrive. This is just after 1.4 firmware and via usb-c cable, Windows 11, Factory SDcard Quote Link to comment Share on other sites More sharing options...
