Why is it so hard to find instruction to perform backup?
boynigel
If it's in the manual, then i'm blind.  my apologies.  Type, "how to backup helix stadium" into YouTube search?  zero results...all for OG Helix.
It was so intuitive with OG Helix- right in the File dropdown you could find, "backup system" or something to that effect.   boom, done.
No such option that i see in the computer app in the File dropdown.  i can export individual (or groups) of presets, but i prefer to be able to save the presets, AND the whole system's setting as it was at the time of backup.
On 9/11/2026 at 8:07 PM, jpdennis said:
@boynigel  Look at the bottom of the online manual for "Helix Stadium Maintenance" (and I have included the direct link below).  It has more maintenance features including how to backup.
https://manuals.line6.com/en/helix-stadium/live/helix-stadium-maintenance
Hope this helps
Dennis
Thanks but i'm only seeing how to back up to the SD card.  i want to back up to my computer
@boynigel Yea, I hear you.  I have a card reader for multiple physical sizes of SD Cards.  I will periodically use the Maintenance screen to eject the SD card.  I then use the reader to backup to my USB drives and a special backup hard drive I have.  It may be a little convoluted but it does work well.  Also, at one point it was suggested backing up the complete folder structure of the SD card this way.  It helps if you format a new SD card and the folder structure is not rebuilt.
The only "at once" trick I found does not backup global settings.  However, if I highlight all my presets and perform an export it does backup all the preset individually at once.  It DOES NOT ask if you want to over right any existing however.
Dennis
The SD cards are small so dirt cheap. Go into maintenance and eject the card. pop it into your computer and copy the entire card into a folder. Then take another SD card and copy it all back onto the new card and pop it back in to the Helix. This way you know your backup works as you are using it. You have a copy of the existing card on your laptop and also a spare card you can quickly swap back in if needed.
Then simply cycle the two cards the next time. And if you really want to, keep the versions of backups on your laptop/PC
On 9/13/2026 at 6:34 PM, boynigel said:
I wonder if future updates can have the Stadium be able update "everything" in one fell swoop?
Would be really nice I agree and sounds simple enough unless files are locked exclusively when in use so can't be accessed by two process at once which may be why its done in maintenance mode?
On 9/12/2026 at 2:23 AM, VGK17 said:
You have to export your set lists or presets to your computer. Stadium does backup differently than the original Helix does.
Yes you can do this but I don’t recommend it unless you’re very careful to manually maintain a method to track compatibility. You need to understand that individual backups of these items can’t just be reloaded independently at a later date and expect things to work together properly. By ‘things’ I mean the tightly integrated set of data that exists on the Stadium device. Among other things it contains User Presets, Setlists (aliases of Presets), and Showcase Songs (containing Flags that can reference Presets). If you simply load a backed up copy of your User Presets you can easily break any references to existing Presets contained in your Setlists or Songs.
With OG Helix you only had to keep Presets and IRs compatible manually. With Stadium there are more individual items that you can export/import individually yet are interdependent: User Presets, Setlists, Songs, IRs, and Clones. These (at least) compromise a tightly integrated dataset.
