Dshow Posted May 22, 2014 Share Posted May 22, 2014 Hi, Is it possible to change the setlist with a footswitch? I mean with the bank selection you can switch through the banks of the actual setlist. But what if I like to change to another setlist. Can this only done manually with the Preset knob? Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 22, 2014 Share Posted May 22, 2014 You can only change setlists manually with the POD HD500/x. With the HD and HD Pro you can use an attached floorboard like the MKII to change using foot switches. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted May 23, 2014 Share Posted May 23, 2014 Check the manual to see if there's a MIDI command to change setlists. If so then you can get a MIDI foot controller to do that. Not very helpful, I know, but it's an idea at least. Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted May 23, 2014 Share Posted May 23, 2014 There's a trick: 1. On the Setup > MIDI page, set MIDI Out/Thru to "OUT" 2. Run a (preferably short) MIDI cable from HD500/500X's MIDI OUT back to its MIDI IN 3. On the MIDI Assign page, from the desired footswitch, set: • MIDI CH to "Base" • Message to "Bank Change" • Bank # to the desired Setlist: Bank #000 is Setlist 1, Bank #001 is Setlist 2, Bank #002 is Setlist 3, and so on 4. From that particular preset, step on the footswitch. POD HD500/500X will jump to the specified Setlist Of course, this implies that you must program the desired setlist into each and every preset from which you may want to access it. Alternatively, you can create a "Bank Jump" preset (at, say, 01A in every Setlist), with Footswitches 1-8 assigned to select Setlists 1-8. Quote Link to comment Share on other sites More sharing options...
Dshow Posted May 23, 2014 Author Share Posted May 23, 2014 Thanks for your replies and the Ideas. I will definatley try out with a Midi cable. Quote Link to comment Share on other sites More sharing options...
radatats Posted May 24, 2014 Share Posted May 24, 2014 Just curious, why would you need to jump setlists at a gig? not enough patches in one set list to get by until the break? If you do jump setlists with the above fix, I assume it goes straight to 01A? How much delay on the setlist switch? Quote Link to comment Share on other sites More sharing options...
Dshow Posted May 24, 2014 Author Share Posted May 24, 2014 Not gigging at all at the time - just playing at home. But I switch between the sets quite often (organized in Styles) and have to crawl under the table or open the Edit software. Can't answer your second question since I haven't tied yet. Quote Link to comment Share on other sites More sharing options...
juicyjones Posted May 24, 2014 Share Posted May 24, 2014 Not gigging at all at the time - just playing at home. But I switch between the sets quite often (organized in Styles) and have to crawl under the table or open the Edit software. Can't answer your second question since I haven't tied yet. Oh I see. That makes sense. Well a decent workaround to get what you want is to use the computer a little differently to help, if you are using a computer, that is. You can mentally set aside one of your setlists for current projects (or two or whatever), and in the desktop software copy patches your're working on to it from their different styles. You can then copy them back later if you like the changes you made, or just leave them. Then you can export and import whole setlists in the desktop software to make it easy to switch projects. I do things this way. In fact, I backed up all the presets that came with it and pretty much don't use most of them, but they're all saved as setlists. Just curious, why would you need to jump setlists at a gig? not enough patches in one set list to get by until the break? If you do jump setlists with the above fix, I assume it goes straight to 01A? How much delay on the setlist switch? I love your sig and am now working tirelessly in fireworks to copy it shamelessly... Quote Link to comment Share on other sites More sharing options...
Dshow Posted May 25, 2014 Author Share Posted May 25, 2014 Thanks for the suggestion - I guess I will reorganize my setlist ;-) Quote Link to comment Share on other sites More sharing options...
