ezaz Posted September 14, 2014 Share Posted September 14, 2014 Hi I have my dreamrig with JTV, pod hd 500x and the l2m. Is it possible to change the settings of the l2m with link 6 link like changing from PA to acoustic to electirc and so on? If not, maybe a good option for the next ypdate for Pod HD 500x Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 14, 2014 Share Posted September 14, 2014 Yes you can do that. The L2m speaker mode setting is saved with the HD500x preset, although it's not obvious. You have to manually set the speaker mode on the L2m to the desired state and then SAVE the preset on the HD500x. After doing that, the speaker mode is automatically reset each time you recall the HD500x preset. Quote Link to comment Share on other sites More sharing options...
Tboneous Posted September 14, 2014 Share Posted September 14, 2014 Does the HD500 do the same thing? Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 14, 2014 Share Posted September 14, 2014 Yes, as of firmware v2.1 and all subsequent releases. Quote Link to comment Share on other sites More sharing options...
dx2ylhv1a Posted September 15, 2014 Share Posted September 15, 2014 Does output of the L2M mirror the speaker mode setting? So if I'm in electric guitar mode and the output is going to FOH that is what is sent to the PA? Thanks Quote Link to comment Share on other sites More sharing options...
zaphodboy Posted September 17, 2014 Share Posted September 17, 2014 Hi I have my dreamrig with JTV, pod hd 500x and the l2m. Is it possible to change the settings of the l2m with link 6 link like changing from PA to acoustic to electirc and so on? If not, maybe a good option for the next ypdate for Pod HD 500x Hi. I have copied a reply I made from a similar query which might help... Run a DMX cable between the Pod and the L2 using L6 link. This way you can switch speaker modes per patch depending whether you want electric or acoustic tones. You cannot save the speaker modes via HD edit though. To get the Pod to change modes dial in your tone as normal using HD edit, manually switch to the required mode on the Stagesource speaker the hit save on the Pod, not HD edit. If you save via HD edit the speaker mode will default to PA mode. Hope that helps, good luck Quote Link to comment Share on other sites More sharing options...
sinistralx Posted January 20, 2015 Share Posted January 20, 2015 Is there any difference between the Lin6 brand L6 Link cable and a regular XLR cable? Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 20, 2015 Share Posted January 20, 2015 Yes. There are basically three types of cable with XLR-type end connectors. Standard XLR cable is designed to carry an analog audio signal. Both DMX and AES/EBU are designed to carry digital information, which is the type of information used in L6 Link communications. Wkipedia can help you get much more info if you like. In practical terms, standard XLR will work OK as an L6 Link cable over short distances. Quote Link to comment Share on other sites More sharing options...
sinistralx Posted January 20, 2015 Share Posted January 20, 2015 tx Quote Link to comment Share on other sites More sharing options...
