Main :: Variax Guitars / Bass / Workbench
Variax 300 echo from high E string and intermittent model changing problems.
by djc165 on 2012-04-30 12:19:19
I keep getting an echo or double string sound from the high E string of my variax 300.
Any suggestions??
Also, when using alternative tunings after 10-15 mins the variax changes between presets.....is this the 'coffin' problem, if so, any help/advice would be appreciated.
Thanks,
Dom
Re: Variax 300 echo from high E string and intermittent model changing problems.
by djc165 on 2012-05-04 05:01:34
any advice on these would be helpful???
by Line6Hugo on 2012-05-17 17:54:13
Have you tried re-installing the flash memory on the guitar?
http://line6.com/support/docs/DOC-1633
If not, please do so, and if the problems persist, the Variax should be taken to an authorized service center:
http://line6.com/service_centers/">http://line6.com/service_centers/">http://line6.com/service_centers/
Regards,
Line6Hugo
by BrentFrampton on 2013-01-01 00:27:57
Hi Dom
did you resolve your problem? I'd be interested how you did it.
My Variax 300 is faulting in the same way as you describe yours. The problem seems to occur when using custom altered tunings and has only started occuring in the last couple of months. All of my Custom 1 bank are alternate tunings I've created myself but havent had any trouble with them in the past.
I'll try cleaning the connections as suggested in another thread about a similar random patch change problem. Have just got a new computer and not put workbench or monkey on it yet so if a clean does not work will hook up work bench and try what Line6Hugo recommended in the post above.
Incidentally, this guitar developed a random patch changing problem about 18 months after I got it and the dealers here repaired it under warranty (replaced a circuit board if I recall correctly), but that was about 4 years ago and has been ok until recently.
cheers
