clarification w/alt tuning
I think the whole idea of alternate tuning is that it provides a quick and temporary switch to a different tuning, with the intention that you will revert back to your idea of a 'standard' tuning, based on the actual physical tuning of your guitar. If you want a different 'standard' tuning then I suggest you actually tune your guitar to that. Then you can switch models at will and won't need to think about alternate tuning.
what the...it works...whatchu talkin bout Willis?
I just changed a tuning via capo...stores in guitar & works w/all models - sorry if I didn't make myself clear
NOW how to figure the other 1/2 of what I wanna do - basically open D etc but 1/2 step down...maybe I DO have to physically tune this guitar down 1/2 step to achieve a baritone AND additional 1/2 step down?
Sorry Silver ...writing before I read
I was wrong in my earlier reply. I forgot that the virtual capo tunings overwrite whatever slot you save them to on the alt tuning knob on a global basis, not just per model. So it actually does work the way you want.
As far as a half step below baritone, just use the virtual capo feature to create the tuning you want and save it where you want it.
When you're defining a new alt tuning you just have to keep in mind that 12th fret equals to the nut, so if you play all open strings it will give you 1 octave down for all of them. 24th fret will give you 1 octave up, and of course you can get whatever in between. If you want something beyond 1 octave up or down, you'll have to physically tune your guitar to it, but I can't imagine anyone needing more than an octave
I thought you could go higher using a 12 string model and disabling the lower string of the pair giving an octave, and then using virtual capo to move it up - you can certainly do altered tuning Nashville variations (6 string with higher strings from a 12 string set)
Easiest tool to use for adjusting alternate tunings (anything, really) is the free Workbench HD software. In this the video I explain how it's done. Go to 3:10 for the tunings bit.
http://line6.com/news/general/1433
 yes it's easier tool but that doesn't change the alt's in guitar correct? I'm able to change them via virtual capo & store for use w/any model - but I play 1/2 step down mostly & to do say a bass guitar sound would be impossible (just because of that 1/2 step)
You can overwrite any of the alternate tunings slots using Workbench HD or Virtual Capo, except for the "Standard" and "model" slots.
to do, say, a bass guitar sound would be impossible (just because of that 1/2 step)
The furthest you can go down is -12 semitones. If your guitar's standard tuning is E-flat then programming -12 in Workbench HD or strumming an open 6th-string in Virtual Capo will yield a bass E-flat. Hope that answers your question.
