wilson69978 Posted February 18, 2015 Share Posted February 18, 2015 Hello again variax users. I went to the music store today to try out a variax and I was very disapointed. The music strore clerk tried three batteries in three different variaxes and none of them worked. He assumed it was the batteries because none of the knobs lit up when held down. He said that the batteries were in the chargers all the time and should be charged. What gives? Any ideas out there? I can't believe 3 of these guitars were "Broken" or had problems with the electronics. I am wondering if the batteries truly were properly charged at all. Any one else have battery issues? Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted February 19, 2015 Share Posted February 19, 2015 Battery works great. Music stores tend to ignore these things since most guitars don't require a battery. 1 Quote Link to comment Share on other sites More sharing options...
Tboneous Posted February 19, 2015 Share Posted February 19, 2015 Have him hook you up to a POD with a VDI. You don't need a battery for that. 1 Quote Link to comment Share on other sites More sharing options...
wilson69978 Posted February 19, 2015 Author Share Posted February 19, 2015 Ok thank you Charlie and Tboneous. I will do that. Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted February 19, 2015 Share Posted February 19, 2015 Ya, pod is a good way to go. I used to go to pretty much the biggest Line 6 dealer in the UK and they never had a charged battery for a JTV. They did aways say that though! Now I just take my own when I want to try stuff out! Quote Link to comment Share on other sites More sharing options...
russgoos Posted February 25, 2015 Share Posted February 25, 2015 One of my two Variax batteries does not take a charge. Any suggestions, or do I have to replace it? I purchased my JTV59 used and typically power it with the HD500X & VDI. I tried the battery for the first time the other day and no luck. Tried to charge it overnight, no luck either. 1 Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted February 25, 2015 Share Posted February 25, 2015 He said that the batteries were in the chargers all the time and should be charged. Music store gear-jockeys say lots of things...often having absolutely nothing to do with the reality that the rest of us share. In all likelihoood, the batteries had never been charged at all. Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted February 25, 2015 Share Posted February 25, 2015 @russgoos. Sounds like you need a replacement. Like you I use a POD but one off the reasons to swap my v500 for a JTV was the fact you can actually run it off a battery which you could do for about an hour on the v500! That said, I've never actually used it on battery so maybe just save the money? You can always run it on pickups if the POD fails? Quote Link to comment Share on other sites More sharing options...
russgoos Posted February 25, 2015 Share Posted February 25, 2015 @Matt_Brown, thanks for the insight. I do have one working battery, so I'll probably stick with that when I'm not using the POD. Quote Link to comment Share on other sites More sharing options...
wilson69978 Posted February 27, 2015 Author Share Posted February 27, 2015 Ok. thanks for all the replies folks. I did end up buying the guitar. The battery was fine. The battery does not light up the knobs on the guitar unless a 1/4 guitar jack is also plugged in. (EVEN IF THE BATTERY IS FULLY CHARGED) (or the guitar is powered by a DVI (Digital variax input) cable and other appropriate hardware. such as POD HD 500 EFFECTS PROCESSOR.) There is also a button on the back of the guitar's battery compartment to test the condition of the battery. you press the little button and four green lights light up if fully charged. and then you go to 3, 2, 1, then no Light as the battery discharges over time. Also, I learned that the charger is solid red when charging and flashing red when fully charged. Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted February 27, 2015 Share Posted February 27, 2015 Ooo, sorry. Tend to think that peeps would know that. Too easy to assume knowledge... At least now there is a thread to clarify. Thanks for posting! Quote Link to comment Share on other sites More sharing options...
