ejj8469 Posted March 11, 2015 Share Posted March 11, 2015 Greetings fellow tone lovers! I'm brand new to the forum and look forward to your wealth of wisdom. Can anyone recommend a carrying case for a brand new M13? Sweetwater recommended the Gator 16x22 case but it was way too big so I'm sending in back. Thx to all. Quote Link to comment Share on other sites More sharing options...
BrianZachary Posted March 13, 2015 Share Posted March 13, 2015 Also a forum noob, and I just searched around a ton looking for a solution to this problem. Looked at a lot of laptop bags, but the M13 is just a bit too thick for most of those to work. Ended up getting this backpack intended for photographers: http://www.amazon.com/gp/product/B00CF5OGP8/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687762&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B002VPE1WK&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=15M3RFRT07Z6QKBJXT58 I've received the bag, but I haven't actually test fit the M13 yet. The dimensions on Amazon's site line up with the M13, and holding it in my hands it appears it will fit great in the main compartment (after you pull out all the velcro-attached dividers). Planning to throw my SansAmp in the laptop sleeve portion, I think it'll work great. Quote Link to comment Share on other sites More sharing options...
ejj8469 Posted March 16, 2015 Author Share Posted March 16, 2015 BZ, I, too, have just been using a backpack to carry my M13. I use the "TETON Sports Tech The Professional Backpack" that I purchased from Amazon last year ($39.99, free 2-day with Prime). I love this bag for light- to mid-duty action but I wish it had more padding for the M13. Great bag overall, though. Quote Link to comment Share on other sites More sharing options...
rwinking Posted April 17, 2015 Share Posted April 17, 2015 I went to a used computer store and got an old laptop case. I had to remove a couple of the pads inside to make it fit but no big deal at all. Easy to carry and plenty of padding and only $10. I am guessing that a lot of newer laptops are built thinner, so an older one works great and they are glad to get rid of them. Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 17, 2015 Share Posted April 17, 2015 You could check with Jay at Tarcaseco. Give him some measurements and see what he says. tarcaseco@comcast.net 1 Quote Link to comment Share on other sites More sharing options...
GeekyBob Posted April 30, 2015 Share Posted April 30, 2015 While they may be difficult to find, the Furman SPB-8 case works great for the Line 6 M-13.I have my M-13 mounted to the board with Velcro, and I have enough room on the board for both a wah pedal and volume pedal.I will admit that it's larger than what you were originally thinking, but it's fantastic for hauling the M-13 around with other gear. Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted April 30, 2015 Share Posted April 30, 2015 Greetings fellow tone lovers! I'm brand new to the forum and look forward to your wealth of wisdom. Can anyone recommend a carrying case for a brand new M13? Sweetwater recommended the Gator 16x22 case but it was way too big so I'm sending in back. Thx to all. I sold my M13, but when I had it, I also used a TC Helicon voice live unit (sold that too!) and they fit near perfectly side-by-side in a case I got from Musicians Friend. Not sure if the smaller case would fit, will check the sizes. Nice case though! Brand is "Diago" If you do go for a larger than needed hard case, it gives you some room to add things like an expression pedal, velcro down the power supply, and a wireless transmitter, etc. The M13 size is: 15.5" (L) x 12" (W) x 3.5" (H) http://www.musiciansfriend.com/amplifiers-effects/diago-pb02-gigman-pedalboard PB02 Gigman Pedalboard Internal Width: 600mm (23-½") Internal Depth: 300mm (11-¾") Internal Height: 85mm (3-¼") http://www.musiciansfriend.com/amplifiers-effects/diago-pb03-showman-pedalboard PB03 Showman Pedalboard Internal Width: 750mm (29-½") Internal Depth: 350mm (13-¾") Internal Height: 100mm (4") Quote Link to comment Share on other sites More sharing options...
jwoertz Posted December 7, 2015 Share Posted December 7, 2015 Old topic, I know, but the empty case for a PedalTrain Jr. worked for me. Quote Link to comment Share on other sites More sharing options...
rumbl Posted December 31, 2015 Share Posted December 31, 2015 I have my M13 mounted to a PedalTrain PT2. It fits with Mission expression pedal and a few other pedals mounted and it all fits in the PedalTrain anvil case. Quote Link to comment Share on other sites More sharing options...
jbenge08 Posted January 15, 2016 Share Posted January 15, 2016 This might be too late but for the time being I found a case at Harbor Freight. For $20 (and it locks) it's been good. http://www.harborfreight.com/18-in-x-6-in-x-13-in-silver-aluminum-case-69315.html It does the trick. I actually have it upside down (the case). That way when I play I just open it up and it stays up. Having the case open kinda helps seeing the screen and the lights too since it blocks some stage lighting. For only $20 something dollars it's not bad. I've been using it for almost a year now. It literally fits perfectly. When open, I'm still able to plug in the guitar cables and power supply. I might actually make one only so I can accommodate a volume pedal but it's not totally necessary. Plus it would be nice to store the power supply in the case as well, not a deal breaker. I usually have the power supply and guitar cables in my guitar Road Runner Gig Bag ( to limit additional bags). Or if I change up my set up I bring my hardshell guitar case with a separate bag with other guitar cables and extra strings. Plus it comes with foam too so when I'm walking around with the case there's absolutely no movement inside. Hope this helps. Quote Link to comment Share on other sites More sharing options...
