Mastersonics Posted March 23, 2015 Share Posted March 23, 2015 Hi everyone I looked around and couldn't find a clear guitar setting for this song...I've seen a few videos too but they don't show how to set it up.Can anyone help me out on a step by step how to set it up and use the wah for the GTR detune? thanks a lot Charles Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted March 23, 2015 Author Share Posted March 23, 2015 Anyone...? Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted March 25, 2015 Author Share Posted March 25, 2015 Bueller... Anyone... Anyone? Quote Link to comment Share on other sites More sharing options...
smrybacki Posted March 25, 2015 Share Posted March 25, 2015 Bueller... Anyone... Anyone? I feel bad that nobody has tried to help and I wish I could, but honestly? I have no earthly idea what you are talking about song or sound wise lol. Perhaps some background? Things like who's the original artist and a short sound clip or video perhaps? Then at least you'd have a starting point for others to chime in with sounds they may have created themselves for other purposes that may work in your context. 1 Quote Link to comment Share on other sites More sharing options...
duncann Posted March 25, 2015 Share Posted March 25, 2015 Try putting a pitch glide somewhere before the amp, set the mix to 100%. Then assign the pitch parameter to either EXP1 or EXP2, with the min and max values at -12 and 0, or 0 and -12, depending on how you want pitch down to operate. That is, the detune will occur with the pedal in the heel position with a min value of -12, or it will occur in the toe position with a min value of 0. The manual contains better detailed instructions for each of the actions outlined above. Just noticed this: If you do this directly on the device, the min and max value range are from -24.0 to 24.0. But if you use the hd edit software, the min and max value range are from 0% to 100%. A little bit of an inconsistency. So in the case of percentages, you'd use the ranges of 25% (min) to 50% (max) or 50% (min) to 25% (max). This would be for an hd500x. Not sure how this works if you have an hd300 or hd400. Quote Link to comment Share on other sites More sharing options...
FlyingsCool Posted March 25, 2015 Share Posted March 25, 2015 I assume you saw this... Quote Link to comment Share on other sites More sharing options...
BCproducer Posted March 26, 2015 Share Posted March 26, 2015 It's possible to do with the expression pedal and pitch glide but a pain in the butt. My less eloquent solution is to set a hd500x patch to tell me variax to drop an octave and I play that riff an octave higher (around 7th/5th fret) but the lower tuning allow me to achieve a pretty close sound with a slide down instead of a pitch effect. If you don't have a variax, you could try using the pod to do the guitar an octave. Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted March 28, 2015 Share Posted March 28, 2015 There was a great patch for this for XT but since upgrading to 500X I can't replicate it. The XT patch won't run through the converter. There is a patch in Customtone that gives you the whammy dive bomb but, for me, it doesn't work in the song. I now use a work around with two patches. Both with a nice 'Black Keys' sound but one with a drop D tuning for my JTV and play the riff in drop D and get the 'bomb' by pressing the E string behind the nut. OK, it's not the same but 'it does'. You could play the whole song in drop D but i don't like to so i switch to the std tuning patch as i go into the verse. Hope this helps! . e riff Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted March 28, 2015 Author Share Posted March 28, 2015 Hi everyoneSorry but for some reason i wasn't getting the replies via email....Still don't know how to do this but will check your comments and take it from there.. If anyone have the patch please let me know ASAP thanks,Charles Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted March 28, 2015 Share Posted March 28, 2015 There is still one in customtone. You just need to look ;-) Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted March 28, 2015 Author Share Posted March 28, 2015 Hi Matt It would've been better to post the link don't you think?.... ;-) thanks C Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted April 8, 2015 Share Posted April 8, 2015 Didn't realise that I was your momma ;-). I posted that reply on my phone! Couldn’t find the patch that I think I downloaded so here is a copy. As I said, it's not brilliant... Have fun! Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted April 8, 2015 Author Share Posted April 8, 2015 Hey Matt If you want to be my momma then... lol Sorry but there's no link to the patch C Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted April 9, 2015 Share Posted April 9, 2015 Ah, where did that go then! I'll try and sort it tomorrow.. Did you wash behind yo' ears? Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted April 10, 2015 Share Posted April 10, 2015 OK, so it won't let me attach a 500X file! Can I use html to make a link? Try downloading from www.msbco.co.uk/lonley boy.5xe See if we can do it! Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 10, 2015 Share Posted April 10, 2015 I think you are going to have to remove the space between "lonely" and "boy" in the file itself, to get that link to work. Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted April 10, 2015 Author Share Posted April 10, 2015 Yes mom I did washed myself it's Friday... lol couldn't get the file at all mom... C Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted April 11, 2015 Share Posted April 11, 2015 The file is at that location. If you copy it and paste it in the addess bar it should open in Edit. The file name has a space in it so shouldn't cause a problem. When i next put the pc on I'll try imbedding it in a page Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted April 11, 2015 Share Posted April 11, 2015 OK, visit this page - there is a link here: http://msbco.co.uk/lb.html I'm not sure that it is worth it! Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted April 11, 2015 Author Share Posted April 11, 2015 Hey Mom, I mean Matt :P I tried it and it's telling me that the download is not supported Don't worry about it brother thanks a lot for trying helping me out cheers, Charles Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted April 11, 2015 Share Posted April 11, 2015 Load the html page I made - the one called 'lb.html' then right click on the link and hit download. That should sort you! Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted April 11, 2015 Author Share Posted April 11, 2015 It won't work maybe because I'm on a Mac? Don't worry about it thanks, C Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted April 11, 2015 Share Posted April 11, 2015 I have the bit between my teeth now! You just need to visit that page and do whatever you would do to download a file! failing that message me an email address and ill send it to you! Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted April 12, 2015 Share Posted April 12, 2015 I saw in another thread that peeps are attaching zip files. Can you get it from here? Peace... LonleyBoy.zip Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 13, 2015 Share Posted April 13, 2015 This is from the zip file version above, I am also on a MAC. "Invalid data found in one or more patches. These patches have been reset and renamed "New Tone (Reset)"." Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted April 13, 2015 Share Posted April 13, 2015 Lol, that was the wrong file! Try this one.! BlackKeysLonel.zip Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 13, 2015 Share Posted April 13, 2015 What variax model are you using with this? Just curious. I have my own Lonely Boy patch but I wanna compare. :) Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted April 13, 2015 Author Share Posted April 13, 2015 Hey Mom... :-) I will check when I get home... Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted April 13, 2015 Share Posted April 13, 2015 Not sure as I dont use the patch. The treble side is not bright enough to make the riff audible to me. This whole thing started because Charlie wanted a patch with the pitch drop and this is the only one ive ever found where it works on a 500X. I got it from CustomTone but it dosent seem to be there any more. I didnt want to post it back there as, frankly, I dont want to be associated with it! if you have one please post it or put a copy here as it would be great to have a good one! Thanks! Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted April 13, 2015 Author Share Posted April 13, 2015 Leesteel I have the JTV69 (love that neck) C Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 13, 2015 Share Posted April 13, 2015 It's been my experience that most patches, shared, don't translate well between guitars and rigs but I will post mine (tonight) here as well. The only reason I didn't post mine was that I didn't want to hear a bunch of posts about how it doesn't sound right. All I know is that it works for my situation. Mastersonics,,,,, my 500 matches my clown shoes. :D Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted April 13, 2015 Share Posted April 13, 2015 Fully appreciate what you say Lee. I have a Dream Rig so sounds should translate between gear however, there are lots of posts here saying 'this or that doesn't sound right' and what people seem to forget that we all have ears and what sounds good to one person might not sound good to someone else. We can only help each other with the tech! I really hear wht you say in "all I know is it works for my situation". I hope that that is what all if us are aiming for! Thanks. Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted April 13, 2015 Author Share Posted April 13, 2015 Hi Matt Just got home and tried the patch and it's PERFECT but I think I have a problemThe main sound of the guitar sounds muffled with no definition... I will try to fix it, maybe it's my system not working correctly.... cheers,Charles Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 14, 2015 Share Posted April 14, 2015 So here is the patch I have been using. http://www.leesteel.com/l6/Lonely-Crunch.5xe Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted April 14, 2015 Author Share Posted April 14, 2015 Perfection.... leesteel This have been my quest for a little while and you NAILED IT...! thanks so much it works perfectly cheers,Charles Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted April 14, 2015 Author Share Posted April 14, 2015 Matt Mom I will see what's wrong with my system because after checking both patches they are very similar but for some reason yours does not work like it supposed...Ghost in the machine perhaps? thanks so much for your help with this truly appreciated Charles Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 14, 2015 Share Posted April 14, 2015 Matt Mom I will see what's wrong with my system because after checking both patches they are very similar but for some reason yours does not work like it supposed... Ghost in the machine perhaps? thanks so much for your help with this truly appreciated Charles Which one doesn't work and what isn't working? My patch is tweaked to use Variax 500 / Special-1 Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted April 15, 2015 Author Share Posted April 15, 2015 Hey leesteel Yours works and after doing a reset Matt's is working as well Ghosts in the machine... B) thanks a lot guys C Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 15, 2015 Share Posted April 15, 2015 I also use this same patch for The Toadies - Possum Kingdom Quote Link to comment Share on other sites More sharing options...
Mastersonics Posted April 15, 2015 Author Share Posted April 15, 2015 Great song forgot about that one...! Quote Link to comment Share on other sites More sharing options...
