Onomatopoeia Posted November 25, 2015 Share Posted November 25, 2015 As the title says, is this possible? In my signal-chain I have the Tube Compressor and then the Vintage Distortion (in that order). When I'm not using the distortion, I like to have the comp on, and when I engage the distortion, I want the comp to go dissengage. I'm able to assign them both to one switch (multi) but when I do that the light is on when I have the comp engaged and off when the dist is engaged. I need it to be the other way around! If i change the order of the signal chain (dist -> comp) it seems to work, but I much prefer the comp -> dist for som reason, even if the comp is dissengaged... Any suggestions? /Danne Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted November 25, 2015 Share Posted November 25, 2015 The light functions based on the the first block of the chain. Quote Link to comment Share on other sites More sharing options...
Dshow Posted November 26, 2015 Share Posted November 26, 2015 As the title says, is this possible? In my signal-chain I have the Tube Compressor and then the Vintage Distortion (in that order). When I'm not using the distortion, I like to have the comp on, and when I engage the distortion, I want the comp to go dissengage. I'm able to assign them both to one switch (multi) but when I do that the light is on when I have the comp engaged and off when the dist is engaged. I need it to be the other way around! If i change the order of the signal chain (dist -> comp) it seems to work, but I much prefer the comp -> dist for som reason, even if the comp is dissengaged... Any suggestions? /Danne I do assign more effects to one switch all the time but didn't care about lights. I have to analyze that. If it's like pianoguyy said, you can't do much about it. I'm not with my POD right now but I'd try to change the way you assing the effects to the switch. First empty the switch to no functionality. Then switch the Compressor off Switch the distortion on Assign both effects to the disired switch If you like to have the clean tone when changing the patch just click on press the switch before saving, so that the distortion is off and the comp on. I'm not sure if this works but I think I remember doing so in the past. Have to try this when I have time. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted November 27, 2015 Share Posted November 27, 2015 The light functions based on the the first block of the chain. Not the entire chain. Just the blocks assigned to the same switch. Quote Link to comment Share on other sites More sharing options...
Onomatopoeia Posted November 27, 2015 Author Share Posted November 27, 2015 Not the entire chain. Just the blocks assigned to the same switch. This seems to be true, sadly enough. Thanks for the help guys! Quote Link to comment Share on other sites More sharing options...
