bsheen Posted January 13, 2016 Share Posted January 13, 2016 Had an idea...anyone ever tried an external EQ in the effects loop with the loop "block" placed after the amp to roll the highs off? I know its been mentioned that using the global eq rolls off the highs of everything, including effects, and using some of the on-board eqs color the sound. Just thought this might be a work around to get rid of the unwanted freqs above 10khz since there is not one on the cab section? Well at least that's where I set mine. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted January 14, 2016 Share Posted January 14, 2016 Why not just use one of the built-in EQs? They aren't very dsp-hungry I don't think. Quote Link to comment Share on other sites More sharing options...
duncann Posted January 14, 2016 Share Posted January 14, 2016 You must be referring to the HD? This sort of thing isn't a problem with Helix. Quote Link to comment Share on other sites More sharing options...
bsheen Posted January 14, 2016 Author Share Posted January 14, 2016 Ok I'm a bit of a goof. How do I move this to the "HD" community. Didn't mean to post this here. Quote Link to comment Share on other sites More sharing options...
duncann Posted January 14, 2016 Share Posted January 14, 2016 I think you have to get someone to move it. Not sure who can do that. Maybe one of the Line 6 Experts roaming around. Or I see threads moved occasionally, so someone might see it and just move it. Anything above 10Khz is what I find myself cutting often also. Sometimes I might go to 8Khz. Depends somewhat on the cab and mic being used. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted January 14, 2016 Share Posted January 14, 2016 Yeah, but are you using every slot in the patch? Because the EQs in the HD are just fine, too. Don't take a lot of juice. Quote Link to comment Share on other sites More sharing options...
bsheen Posted January 14, 2016 Author Share Posted January 14, 2016 Anything above 10Khz is what I find myself cutting often also. Sometimes I might go to 8Khz. Depends somewhat on the cab and mic being used. It makes a huge difference! I was totally thrilled when they added it to the HD. Though having that feature in the cab section would be even better. Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 14, 2016 Share Posted January 14, 2016 Ok I'm a bit of a goof. How do I move this to the "HD" community. Didn't mean to post this here. Moved Quote Link to comment Share on other sites More sharing options...
bsheen Posted January 14, 2016 Author Share Posted January 14, 2016 Thanks! Quote Link to comment Share on other sites More sharing options...
Brazzy Posted January 14, 2016 Share Posted January 14, 2016 Sometimes I use the EHX Tube EQ from the Pod's 1/4" out then to the FX Return of an amp. Most of the time I use the Pod's FX Return for a Drum Machine and the send can go into another amp. Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted January 14, 2016 Share Posted January 14, 2016 I'm not sure what the advantage would be given how simple it is to solve this with the GEQ. Why add another point of failure along with additional complexity in your setup? Quote Link to comment Share on other sites More sharing options...
giallanon Posted January 14, 2016 Share Posted January 14, 2016 I do it. I put the fxloop after the mixer block and use send/return to link the HD500x to an MXR 10 band eq. Why I don't use one of the hd500x eq? Well, because I need more band than what HD has to offer. HD500x does not have a 10 band EQ for example. Sure, if you only need a low pass filter to kill high freq, you can use a parametric EQ or a vintage-pre or the global EQ but, if you want a better control, an external EQ is not a bad idea IMO and that's why the fxloop exists, to expand the HD500x capabilities with external gear. Quote Link to comment Share on other sites More sharing options...
bsheen Posted January 15, 2016 Author Share Posted January 15, 2016 I'm not sure what the advantage would be given how simple it is to solve this with the GEQ. Why add another point of failure along with additional complexity in your setup? The global EQ to my knowledge affects the entire signal path, so you'd be cutting(in this case) all the delays, reverbs etc. that are after the amp. I'd like to be able to cut just the highs on the cabinet, then let everything else "breath" if you will. Quote Link to comment Share on other sites More sharing options...
duncann Posted January 15, 2016 Share Posted January 15, 2016 The global EQ to my knowledge affects the entire signal path, so you'd be cutting(in this case) all the delays, reverbs etc. that are after the amp. I'd like to be able to cut just the highs on the cabinet, then let everything else "breath" if you will. That's interesting. I wonder if effects like delays and reverbs produce frequencies beyond what is put into them? Quote Link to comment Share on other sites More sharing options...
clintmartin Posted January 15, 2016 Share Posted January 15, 2016 I use the mid focus eq after the mixer for a HP/LP filter. Turn the gain down to zero and it works great. 1 Quote Link to comment Share on other sites More sharing options...
