kevliao Posted January 25, 2016 Share Posted January 25, 2016 I was playing around with the looper. Somehow I ended up adding a looper block to the end of the signal chain for every preset. I've played around with global settings and footswitches, but can't get rid of the looper for every preset, only one at a time. I know I can do a hard unit reset as well. Thanks! Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 25, 2016 Share Posted January 25, 2016 Maybe you didn't actually somehow add the looper to every factory preset. I don't recall exactly, and I don't have my Helix with me right now, but I know many of the factory presets already have a looper block at the end of the chain. But the factory presets named New Preset are completely empty. Check some of those. If they do have the looper block then you somehow found a way to add a looper globally to all presets, a capability that I don't think exists. I don't know of a way to remove the looper block from multiple presets simultaneously. Quote Link to comment Share on other sites More sharing options...
capdoogie Posted January 25, 2016 Share Posted January 25, 2016 I believe every or almost every factory preset has looper block. You have to delete each one in each preset Quote Link to comment Share on other sites More sharing options...
fukuri Posted January 25, 2016 Share Posted January 25, 2016 Unless you have to remove it I would leave it there Remember if you have the looper block in the same position the looper will persist through the preset changes Quote Link to comment Share on other sites More sharing options...
tagmusenmagnus1 Posted January 25, 2016 Share Posted January 25, 2016 Unless you have to remove it I would leave it there Remember is you have the looper block in the same position the looper will persist through I preset changes Sorry. What was the last thing you said ? :p Quote Link to comment Share on other sites More sharing options...
fukuri Posted January 25, 2016 Share Posted January 25, 2016 Bloody phones A combination of chubby fingers and enthusiastic auto correct Edited for the queens English Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted January 26, 2016 Share Posted January 26, 2016 Nearly all factory presets have a looper, but they're per preset, not global. Should take two seconds to delete it: From Stomp mode, touch the Looper switch. Press ACTION and then Knob 3 (Clear Block). If you're not into loopers, removing the Looper block will give you a bit more DSP horsepower (and an extra stomp switch, obviously). 1 Quote Link to comment Share on other sites More sharing options...
