Bommeltje Posted January 27, 2016 Share Posted January 27, 2016 Hi there, let me start of by saying that I absolutely love the Helix: The sounds, the ease of use, the flexibility, the looks! However, at this moment my Macbook pro and Helix don't communicate that well. The App is very unstable and crashes every few seconds/minutes when exporting or importing or doing nothing at all, can't find the Helix, disconnects and gives me messages like: "No symbol lookup table present for models and parameters", and so on. Today I installed the update and the problem persists, no worse no better, but just almost impossible to work with. I have a ticket open on this issue, so I'm expecting it to be solved anytime soon. I opened this topic, to see if anybody has found a practical workaround for this and to learn from other experiences. tnx! Quote Link to comment Share on other sites More sharing options...
Bommeltje Posted January 27, 2016 Author Share Posted January 27, 2016 Update: I used an old powered USB 2.0 hub (brand: Elecom) between the Helix and the macbook pro and the Helix app is stable! Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted January 27, 2016 Share Posted January 27, 2016 What OS is your mac running? OS X El Capitan is a known problem with EVERYBODY's hardware. Quote Link to comment Share on other sites More sharing options...
Bommeltje Posted January 27, 2016 Author Share Posted January 27, 2016 I'm running El Capitan but I cant confirm issues with other hardware. Just the Helix Quote Link to comment Share on other sites More sharing options...
stephenashworth Posted January 31, 2016 Share Posted January 31, 2016 it is fixed in 10.11.4 (beta) for me. :-) Quote Link to comment Share on other sites More sharing options...
Bommeltje Posted February 1, 2016 Author Share Posted February 1, 2016 Update: I used an old powered USB 2.0 hub (brand: Elecom) between the Helix and the macbook pro and the Helix app is stable! Update again: the crashing of the app appears so random that I thought the hub was a solution. Today I found that it's still very unstable: - crashes when exporting - imports go wrong: Presets are all empty or all presets have the same settings I hope an OSX update solves this or that Line 6 will come with a solution. I just don't want to loose hours of work!! Quote Link to comment Share on other sites More sharing options...
floyd99 Posted February 3, 2016 Share Posted February 3, 2016 Just got my Helix today. I have exactly the same problem. The Helix software keeps losing connection with the unit. Haven't tried a different cable yet.. Using the one that came with the helix. But I know it's not my macbook Quote Link to comment Share on other sites More sharing options...
mmarinic Posted February 4, 2016 Share Posted February 4, 2016 Similar problem here. iMac (32 gb, 4 yrs old) app worked intermittently at best, not usable. No hub. Tried everything. Then connected helix to my mbp and it worked flawlessly the first time. Something not right with the iMac software stability. Quote Link to comment Share on other sites More sharing options...
abrady44 Posted July 8, 2025 Share Posted July 8, 2025 Hi, I have the same issue, it happens on both my PC and my Mac. I have it set up so the helix is the output audio device on my computer, so I can play along with jam tracks on my studio monitors (which are hooked up to the helix outputs). Unfortunately, the helix connection to the computer interrupts every few minutes, so the song stops and I have to reconnect it. Super annoying that a simple setup like that doesn't work. I've tried multiple USB cables and 2 different computers running different OS's and it's the same issue. Not really sure what's wrong. Quote Link to comment Share on other sites More sharing options...
datacommando Posted July 8, 2025 Share Posted July 8, 2025 On 7/8/2025 at 1:09 AM, abrady44 said: Hi, I have the same issue, it happens on both my PC and my Mac. I have it set up so the helix is the output audio device on my computer, so I can play along with jam tracks on my studio monitors (which are hooked up to the helix outputs). Unfortunately, the helix connection to the computer interrupts every few minutes, so the song stops and I have to reconnect it. Super annoying that a simple setup like that doesn't work. I've tried multiple USB cables and 2 different computers running different OS's and it's the same issue. Not really sure what's wrong. You’re a little late to the party - this thread is 9 years old, and the USB connection issues have been done to death. Rather than another “me too”, post it is advisable to do a thorough search through the the vast amount of posts in here that cover the issues of USB voodoo. Suffice to say, I have my Mac connected to my Helix floor via USB, and it has been used almost daily for 10 years without issues. Playback of backing tracks from iTunes (Music), recording and playback from Logic, etc. - it just works. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
