glideman Posted March 10, 2016 Share Posted March 10, 2016 I played ONLY with the 5150, which is not MY favorite model. By the time I got through most of the cabs and the mics on each one... WOW!!!!!!!!! Way more tones in there than the HD500X had! I have a feeling I'm going to be deep tuning cabs on all of my presets now. Don't even have to touch an amp parameter for awhile. Just cab tweaking is amazing. Glad I finally had a non lazy moment! 1 Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted March 10, 2016 Share Posted March 10, 2016 I played ONLY with the 5150, which is not MY favorite model. By the time I got through most of the cabs and the mics on each one... WOW!!!!!!!!! Way more tones in there than the HD500X had! I have a feeling I'm going to be deep tuning cabs on all of my presets now. Don't even have to touch an amp parameter for awhile. Just cab tweaking is amazing. Glad I finally had a non lazy moment! Heck, you can get a lot out a favorite cab model just by changing which mic is on it! And... dual cabs are da bomb. Even in mono. Quote Link to comment Share on other sites More sharing options...
glideman Posted March 10, 2016 Author Share Posted March 10, 2016 Yeah... I haven't even experimented much with dual cabs other than when they were already in a preset. Amazing what you can do to the tone with the stock cabs. Faster than having to load a ton of IR's, too! Quote Link to comment Share on other sites More sharing options...
hideout Posted March 11, 2016 Share Posted March 11, 2016 I seem to find that for overdrive sounds, I don't like anything but the ribbon mics. I must admit that I haven't really explored all the abs as I got tired of switching the mics out to one of the ribbons. I kinda wish that your mic choice and your sag, bias, etc. settings would stay put while you're switching cabs and amps around. Quote Link to comment Share on other sites More sharing options...
geeker Posted March 11, 2016 Share Posted March 11, 2016 dude..... I can't wait to get mine!!!!.......... comes in next week...... four days and counting!!! Quote Link to comment Share on other sites More sharing options...
glideman Posted March 11, 2016 Author Share Posted March 11, 2016 Trust me... tweak your cabs and settings! You may find a patch you didn't like turn into a mainstay... Quote Link to comment Share on other sites More sharing options...
hideout Posted March 11, 2016 Share Posted March 11, 2016 Trust me... tweak your cabs and settings! You may find a patch you didn't like turn into a mainstay... Yup. I have to get out of my tweaking rut. :lol: Quote Link to comment Share on other sites More sharing options...
amsdenj Posted March 11, 2016 Share Posted March 11, 2016 I seem to find that for overdrive sounds, I don't like anything but the ribbon mics. I must admit that I haven't really explored all the abs as I got tired of switching the mics out to one of the ribbons. I kinda wish that your mic choice and your sag, bias, etc. settings would stay put while you're switching cabs and amps around. They can, sort of. If you're trying to make modifications to a patch, and want to be able to A/B compare the patch, then simply clone it to the next patch up. Leave one as the original, unchanged patch, say A. Use the second to try changes to compare to A. Switch to B, make a change press Save twice. Then you can switch between A and B to compare the two. If you like B better, save it to A and start the process again with the next change. Quote Link to comment Share on other sites More sharing options...
spikey Posted March 12, 2016 Share Posted March 12, 2016 Very promising- thanks for the info! Quote Link to comment Share on other sites More sharing options...
hideout Posted March 12, 2016 Share Posted March 12, 2016 They can, sort of. If you're trying to make modifications to a patch, and want to be able to A/B compare the patch, then simply clone it to the next patch up. Leave one as the original, unchanged patch, say A. Use the second to try changes to compare to A. Switch to B, make a change press Save twice. Then you can switch between A and B to compare the two. If you like B better, save it to A and start the process again with the next change. Hmmm... Thanks but doing that would drive me batty. 1 Quote Link to comment Share on other sites More sharing options...
