BobbyD79903 Posted March 10, 2016 Share Posted March 10, 2016 As owner of pro video comp, could not overlook battery is identical in form and voltage to Sony camcorder batteries. Anyone notice or try this? Only diff appears to be mAh. My cam Batts are all 3300+. Hope they're interchangeable. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted March 10, 2016 Share Posted March 10, 2016 Nope. Won't work. They were able to make their battery unique with a third wire that identifies the battery. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted March 10, 2016 Share Posted March 10, 2016 Nope. Won't work. They were able to make their battery unique with a third wire that identifies the battery. Monopolies are fun... Quote Link to comment Share on other sites More sharing options...
psarkissian Posted March 10, 2016 Share Posted March 10, 2016 And the drain rate is different. Whatever internal diode is in the Sony, will get blown. I used to see this incompatibility problem between batteries with Sony Discman's and Sony laptops. Using third party batteries is a dangerous coin toss for your gear. Normally I'd agree cruisinon2, but here, it's more about the drain rate and yes, the third pin too,... like the 3rd rail on The Underground. Companies want you to use their power sources because they are tailored to and somewhat assured to work with their product. Using a 3rd party power source, you never know what you get or how compatible it. Always a safe bet to go with what's specified. And so as a result there is an electrical reason for the 3rd pin. And those different drain rates do make a difference. Quote Link to comment Share on other sites More sharing options...
BobbyD79903 Posted March 10, 2016 Author Share Posted March 10, 2016 Wow. Glad I asked. I guess it's buy some certified Variax batts time. Thanks to all. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted March 15, 2016 Share Posted March 15, 2016 From the Line 6 Knowledge Base FAQ,...=====================================================================BatteryQ: What kind of battery is used in the James Tyler Variax and what is the battery life?A: JTV guitars use a lithium-ion battery similar to that of a camcorder. A fully charged battery can deliver at least 12 hours of continuous performance. There is a four light battery life indicator on the battery compartment on the back of the JTV guitars that can be viewed by pressing the round flush black button next to the lights.4 LEDs = 9+ hours3 LEDs = 6+ hours2 LEDs = 3+ hours1 LED = less than 3 hours1 LED blinking = less than 1 hour, recharge batteryNote: Using a non-Line 6 JTV battery will void your warranty and may damage your JTV. ===================================================================== This also applies to the Variax Standard. Quote Link to comment Share on other sites More sharing options...
eenymason Posted March 15, 2016 Share Posted March 15, 2016 From the Line 6 Knowledge Base FAQ,... ===================================================================== Battery Q: What kind of battery is used in the James Tyler Variax and what is the battery life? A: JTV guitars use a lithium-ion battery similar to that of a camcorder. A fully charged battery can deliver at least 12 hours of continuous performance. There is a four light battery life indicator on the battery compartment on the back of the JTV guitars that can be viewed by pressing the round flush black button next to the lights. 4 LEDs = 9+ hours 3 LEDs = 6+ hours 2 LEDs = 3+ hours 1 LED = less than 3 hours 1 LED blinking = less than 1 hour, recharge battery Note: Using a non-Line 6 JTV battery will void your warranty and may damage your JTV. ===================================================================== This also applies to the Variax Standard. Can these batteries be used for legacy model variaxes? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted March 15, 2016 Share Posted March 15, 2016 No. Those older ones are +9Vdc system. See the manual regarding the options on those. JTV and Variax Standard batteries won't fit in the compartment. Old stuff is not interchangeable with the newer JTV's and Standard, it's a whole other system, a different beast. Quote Link to comment Share on other sites More sharing options...
BobbyD79903 Posted March 16, 2016 Author Share Posted March 16, 2016 Reply from L6 confirms only L6 batteries and cables must b used. Voids warranty if u don't. As for "new laws" compelling exclusivity, I don't buy it. I've got Sony, JVC, Canon, etc. pro cameras custing $20K+ and even generic batteries are fully compatible. Never liked paying $20 for a Stadium beer and hotdog. But if I'm at the game and I'm hungry... well enough said. A minor disincentive. Just gonna budget $100 for a couple batteries. Do competitive products force their batteries and cables too? Curious. Otherwise, I love the guitar. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted March 16, 2016 Share Posted March 16, 2016 This isn't stadium beer and a dog. And it's not just L6, most gear is design that way for reasons I explained earlier. Has nothing to do with marketing or exclusivity, it has to do with keeping your gear intact and functioning well. That's why I'm here, to keep your gear off my repair bench. Quote Link to comment Share on other sites More sharing options...
BobbyD79903 Posted March 16, 2016 Author Share Posted March 16, 2016 Got it. And I will not test your reply. Love the Variac too much to risk anything. All my L6 gear works impeccably well, year after year. So L6 quality is without question. Pricing for adding a battery chip or diode seems high, nearly double that of comparable Batts for pro video cams WITH proprietary chips that are cross platform compatible. Would also been better to allow generic RJ45 Lan cabling that's available everywhere, should something arise, accidental damage, etc. When on tour, remote jobs, immediate solutions are needed. And next day Fed-X of a L6 cable from GC or Sweetwater rests on them having your cable in stock. I already tried to buy both batt abd cable at my local GC and they won't stock it. Hence my concern is immediate and long term availability of proprietary ONLY parts. We've all had that problem before, and are in a better place when we know we have a reliable supply of essential components to L6 instruments which are otherwise built to last a lifetime. I Bragg heavily about my L6 gear all the time. Just don't liking limitations or pricing in this case. Also stirs hesitation going Fwd when considering newly introduced products. Hope ur engineers can factor my concerns. I've read forums and I'm alone in my view. Thx again. Your support us A1 always and I remain a loyal L6 customer. Thx Bob Quote Link to comment Share on other sites More sharing options...
BobbyD79903 Posted March 16, 2016 Author Share Posted March 16, 2016 Typo... meant to say "I'm NOT alone in my concerns". Also would a little reassuring if dealers are required to stock such important/essential parts ongoing. Is every buyer of an L6 product required to buy backup batteries and cables? Safe to say, the Variax guitars will outlast both otherwise. Hope u take my comments constructively. Not intended any other way. In my opinion, these are the only 2 glitches in an otherwise incredible product. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted March 16, 2016 Share Posted March 16, 2016 Back up battery,... if you want. VDI cable is a must. Too many time a guitar comes back with a regular CAT5 cable. Without the XLR type casing, there can be jiggling to the point of indeterminacy. And to a supply line, transient like that are bad. The they try force it, bent pins occur in the VDI jack, then the real bad stuff happens,... it ends up on my bend for repairs. So using the VDI cable with XLR casings on both sides (not the interface cable) is a good thing. I know all these things because I've worked on hundreds of JTV's (roughly 740+ at last count), so I've seen all the things that can go wrong with them,... and then some. Quote Link to comment Share on other sites More sharing options...
