Not Able To "connect" In Workbench
USB issue perhaps?  Have you tried different ports?  Do not use USB 3.0 ports either.
probably obvious... but the volume needs to be turned up... the electronics turn off if its dialed all the way down...
It worked before with the same USB port.  Volume was up.  Shouldn't it still work without internet access?
1.  Are the lights green on both sides of the Variax USB interface?  It sounds like the USB sides is green and the Variax side is red.
2.  If the Variax side is red, try plugging a normal guitar cable into the 1/4" jack.  Workbenck will not see the Variax unless it is powered on.  The Variax is not powered on unless something is plugged into the 1/4" jack.
BTW, I tried mine while not connected to the internet and it works fine, AS LONG AS I HAVE SOMETHING PLUGGED INTO THE 1/4" JACK!!
Thanks!  Everything was hooked up correctly, but I'm not sure what side the red light was on.  I'll try again this weekend.
  • 2 months later...
The USB interface is unreliable and very finicky. I've had to futz with mine endlessly with a myriad of ethernet cables, standing on my head, rebooting, unplugging and plugging. Sometimes the magic green light is on and it still won't recognize my Variax. A piece of work....
