millywinter Posted May 20, 2016 Share Posted May 20, 2016 I bought this JTV 69 yesterday and I can get it recognised on workbench HD, I have uploaded all to Variax. Battery is fully charged and all the green LEDs come on to show that, but whatever I do, I can only get the natural sound out of it! I know I am probably being stupid, but how do you turn the damn thing on?! Thanks Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 20, 2016 Share Posted May 20, 2016 You need to connect a 1/4" cable to "turn it on". You can't monitor the sound through Workbench though. It's just an editor, there are no amp sims in there, and no output. You gotta plug into something else to evaluate the changes you make. Quote Link to comment Share on other sites More sharing options...
millywinter Posted May 21, 2016 Author Share Posted May 21, 2016 Thanks, but I have the 1/4" plugged in. There is sound coming out of the amp, but the knob to change the instrument and the tuning aren't doing anything. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 21, 2016 Share Posted May 21, 2016 Have you pushed down the Model select knob? That's what switches the sound from mag pickups to modeling. Quote Link to comment Share on other sites More sharing options...
millywinter Posted May 21, 2016 Author Share Posted May 21, 2016 I have solved it - it was a sticky knob. I pulled the knob off and put it back on again and now it presses properly and it is working all perfectly now. Thanks for your help :) Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 21, 2016 Share Posted May 21, 2016 If this happens again, an easy fix is to pull the knob off, place a little wad of crushed paper in the hollow of the knob, and push the knob back on. This raises the knob on the shaft so that the bottom of the knob no longer rubs against the body of the guitar. 2 Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 21, 2016 Share Posted May 21, 2016 If this happens again, an easy fix is to pull the knob off, place a little wad of crushed paper in the hollow of the knob, and push the knob back on. This raises the knob on the shaft so that the bottom of the knob no longer rubs against the body of the guitar. 5 or 6 years in, and we're still fixing new $1000 guitars with little wads of paper and cardboard. Inspiring. 4 Quote Link to comment Share on other sites More sharing options...
rwb1636 Posted November 30, 2021 Share Posted November 30, 2021 Thank you your post was most helpful as Just received a used Line 6 JTV-59 Variax and after pressing the Knob the guitar selection knob wouldn't turn on. I could update firmware and use Workbench. It was frustrating because the software could see the JTV-59. After reading your post I removed the knob and pressed down and selection light came on and everything worked. Obviously it had not been checked out from the retailer. The knob does seem to have a lot of play side to side and the tuning knob does not so will need to inquire about that. The wad of paper works just fine and I now have a working guitar. 1 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 30, 2021 Share Posted November 30, 2021 Second hand from a retailer, and an early serial number. Side to side play,... would be something going on underneath. It should go in for servicing. Maybe I should have a look at it, if it's what I think it is. Quote Link to comment Share on other sites More sharing options...
bluzzy62 Posted March 22, 2025 Share Posted March 22, 2025 Older thread but obviously still an issue for some. I just bought a like new 2019 JTV-69 with this issue, although I'm not 100% convinced the "wad of paper" is the fix, as it appears to be an intermittent problem on mine. I'll try it and let you know, in case others are also having same issue. This is a great forum... thank you all! ☺️ Quote Link to comment Share on other sites More sharing options...
psarkissian Posted March 24, 2025 Share Posted March 24, 2025 There is a fix for that. A space cut just for that, or a replacement knob. A Line 6 authorized service center can take of that. https://line6.com/find/service_center/ If they have any questions they can find me through the usual service tech channel. Quote Link to comment Share on other sites More sharing options...
SuaveNorwood Posted April 5, 2025 Share Posted April 5, 2025 So glad i found this thread and saw that it was such a simple fix. I got a used JTV-69 about a week or 2 ago and all i would get out of it was the sound of the regular pickups. Pressed down on the guitar modelling knob a bit harder than i had done previously and that engaged the modelling and alternate tuning. If this becomes an issue down the line, i'll try the paper fix. Thanks everyone! Quote Link to comment Share on other sites More sharing options...
