lokimoto Posted May 31, 2016 Share Posted May 31, 2016 Hello guys. I do not use USB recording so often, but when I tried yesterday Everything hooked up perfectly and Windows 7 recognized everything. All set! I used the software Audacity, whiuch is very simple to use just to be able to 'hear' the sound coming from Helix. But there was the problem: If I pickd a string, I didnot hear it immediately ... just about 0.5sec later, which is really disturbing! Anyway, anyone here had similar issue? Any tip is highly welcome! Cheers Leo Quote Link to comment Share on other sites More sharing options...
ricksteruk Posted May 31, 2016 Share Posted May 31, 2016 Hi Leo, You need to look at your buffer settings on your PC. Try and get as low a buffer as possible - this will reduce the latency to minimum. On my system it defaulted to 128 samples - giving a latency of just 5 milli seconds. People say we can't hear below about 20ms but you sure can start to feel it by then. Good Luck! Rick Quote Link to comment Share on other sites More sharing options...
lokimoto Posted May 31, 2016 Author Share Posted May 31, 2016 Hi Leo, You need to look at your buffer settings on your PC. Try and get as low a buffer as possible - this will reduce the latency to minimum. On my system it defaulted to 128 samples - giving a latency of just 5 milli seconds. People say we can't hear below about 20ms but you sure can start to feel it by then. Good Luck! Rick Thanks for the tip Rick! I will try it tonight! Leo Quote Link to comment Share on other sites More sharing options...
regalpierot Posted May 31, 2016 Share Posted May 31, 2016 Yup, latency is entirely down to your PCs processor and some fine tuning on the buffer side should do it. It's all about finding the balance where the response time is low enough, but the CPU doesn't thrash causing pops and clicks in your recording. Once you get it though it's definitely set and forget. I will say I've used the Helix on a number of computers and zero noticeable latency, just saying that to alleviate that horrible 'I have a $1500 that doesn't work when connected to a computer' feeling Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 31, 2016 Share Posted May 31, 2016 Hello guys. I do not use USB recording so often, but when I tried yesterday Everything hooked up perfectly and Windows 7 recognized everything. All set! I used the software Audacity, whiuch is very simple to use just to be able to 'hear' the sound coming from Helix. But there was the problem: If I pickd a string, I didnot hear it immediately ... just about 0.5sec later, which is really disturbing! Anyway, anyone here had similar issue? Any tip is highly welcome! Cheers Leo It sounds like you're monitoring through your DAW as opposed to through the Helix itself. If you monitor through the Helix, there should be no latency. Quote Link to comment Share on other sites More sharing options...
Sentox Posted May 31, 2016 Share Posted May 31, 2016 Additionally, due to licensing restrictions the normally available releases of Audacity do not have ASIO support. You either have to dig around online or compile one yourself, so it's possible the OP does not have the option to use ASIO. Quote Link to comment Share on other sites More sharing options...
