talljoe Posted August 10, 2016 Share Posted August 10, 2016 Just got a new standard and am quite pleased with it. Battery was flat out of the box, so i charged it up. I did leave it in the guitar but turned off meddling. two days later it's flat. Is there a trick to this or is the battery a dud. Also, does anyone know what strings are put on at the factory ? I am used to 9's, these feel stiffer. Thanks, TJ Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 10, 2016 Share Posted August 10, 2016 What you have described sounds normal to me. As long as you have a 1/4" cord in the jack the battery is being discharged, whether or not you have modelling engaged. Turning the Vol knob down to zero induces a sort of sleep mode, which helps prolong battery life while a cord is connected. The cord connection is effectively an ON/OFF switch for the battery. The Vol knob is a sort of standby mode. To preserve battery life between sessions unplug the cord. Quote Link to comment Share on other sites More sharing options...
talljoe Posted August 10, 2016 Author Share Posted August 10, 2016 Aaaahhh, that makes sense. Thanks for that, I had left my wireless transmitter jack in. Are the strings 10's, do you know ? TJ Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 10, 2016 Share Posted August 10, 2016 Yes - factory strings are 10s. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted August 10, 2016 Share Posted August 10, 2016 The battery will drain if you leave anything plugged into the 1/4 inch jack. It will last for months if you don't use it. You should get a good solid 6 hours of playing with a fully charged battery. Quote Link to comment Share on other sites More sharing options...
talljoe Posted August 10, 2016 Author Share Posted August 10, 2016 Thanks all. TJ Quote Link to comment Share on other sites More sharing options...
soundog Posted October 10, 2016 Share Posted October 10, 2016 Does it drain with the VDI cable plugged in? Mine seems to.... Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted October 10, 2016 Share Posted October 10, 2016 Does it drain with the VDI cable plugged in? Mine seems to.... Like every other rechargeable battery on earth, it'll drain sitting on a shelf...a bit slower, but drain it will, nonetheless. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted October 10, 2016 Share Posted October 10, 2016 These batteries should not drain quickly on the shelf! Should go 6 months without much loss of charge. If they drain quickly when not used, they are defective. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted October 10, 2016 Share Posted October 10, 2016 These batteries should not drain quickly on the shelf! Should go 6 months without much loss of charge. If they drain quickly when not used, they are defective.Nobody said anything about draining "quickly"...but they will discharge eventually, no matter where they are. He asked if it would drain with VDI connected, which it will. He seemed to be inquiring whether or not the VDI connection would charge the battery...which it doesn't. How long will it last sitting on a shelf? I have no idea, but I know the answer isn't "indefinitely". Never bothered to clock the process, as I don't use the battery anyway. Pretty sure it's dead...hasn't left the guitar case much in 3 years. 1 Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted October 10, 2016 Share Posted October 10, 2016 VDI won't drain the battery! I leave mine plugged in all the time. No it won't charge it though. Lithium batteries have the lowest self discharge rate of any on the market so they will hold a charge a long time if not being drained by the equipment they are connected to. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted October 10, 2016 Share Posted October 10, 2016 VDI won't drain the battery! For the love of God, NOBODY ever said that it did! Not once... But if you leave the battery in the guitar whilst using the VDI connection, it WILL eventually discharge. End of story. Is the VDI "causing" said discharge? NO, of course not. It would be a dumb question to ask, and an even dumber answer to offer. Fortunately for everybody, that's NOT the question that was asked, nor was it the answer that was given. But it ain't gonna stay magically charged forever either. And whether it takes weeks, months or years, is basically irrelevant to the discussion. The guy asked "will the battery drain with the VDI plugged in?" Answer: YES. On a long enough timeline, it will do exactly that. Quote Link to comment Share on other sites More sharing options...
Ivanshaw Posted January 7, 2018 Share Posted January 7, 2018 Excuse my novice question; I understand the battery drives the on-board electronics, but does it also act as amplification for playing? I recently purchased s/h 300. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted January 8, 2018 Share Posted January 8, 2018 Excuse my novice question; I understand the battery drives the on-board electronics, but does it also act as amplification for playing? I recently purchased s/h 300. Not remotely...no guitar on earth has hot enough output to drive a speaker. That requires a power amp. Quote Link to comment Share on other sites More sharing options...
TeleZee Posted January 31, 2018 Share Posted January 31, 2018 I bought my Standard a few months ago and I did find out the hard way not to leave it plugged in. I use it at 2 rehearsals a week plus practice in between. i can usually get 4 rehearsals at 2 hours each (or more) and some time at home before I need a recharge. Not sure if it discharges while plugged into an amp, but it does seem to last pretty well. I don't have on all night, only when I use the effects. I really like the sound of the straight up guitar as well. Quote Link to comment Share on other sites More sharing options...
