talonmm 35 Posted August 11, 2016 Well I ordered what I thought would work fine from ebay in allowing me to play an Ibanez JEM77P guitar with the wireless g10 since the G10 does not quite fit properly into the guitar cavity (here's the link).... http://www.ebay.com/itm/400667246204?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT The item I ordered was a Stereo 6.35mm Female Socket to Male Mono ¼" Guitar 6.35mm Jack Plug Adapter. The adapter worked but very poorly. It added for lack of a better word, overdrive on clean sounds, and I believe the volume suffered and was coming in and out. The size and footprint are perfect. Can anyone recommend a better adapter solution? thanks! Quote Share this post Link to post Share on other sites
DarrellM5 170 Posted August 12, 2016 What worked for me is a 1/4" mono to 1/4" mono adapter, which I bought for a similar price to the one you purchased. Quote Share this post Link to post Share on other sites
KuRiXY 2 Posted August 17, 2016 Exactly, you just bought the opposite, you need mono to stereo or mono to mono :) But not stereo->whatever, or the unit will think it is charging :) Quote Share this post Link to post Share on other sites
crm3550 6 Posted October 12, 2016 I found a workaround on the transmitter not fitting into the guitar input. I have a Ibanez S series with the recessed 1/4" plug. I removed the back plate lossened the jack and placed a 1/4" thick by 3/4" diameter rubber washer on the outside of the jack. This gave plenty of room for the G10 transmitter to connect. 1 1 Quote Share this post Link to post Share on other sites
KuRiXY 2 Posted October 12, 2016 Nice solution, and nice guitar, I love those S series with synchronizr bridge :) Quote Share this post Link to post Share on other sites
MusicLaw 215 Posted October 12, 2016 Nicely done! Quote Share this post Link to post Share on other sites
Jaret 0 Posted January 17, 2017 I found a workaround on the transmitter not fitting into the guitar input. I have a Ibanez S series with the recessed 1/4" plug. I removed the back plate lossened the jack and placed a 1/4" thick by 3/4" diameter rubber washer on the outside of the jack. This gave plenty of room for the G10 transmitter to connect. Can you post a picture of inside the back plate where you placed the washer? This is genius! Quote Share this post Link to post Share on other sites
crm3550 6 Posted January 17, 2017 Can you post a picture of inside the back plate where you placed the washer? This is genius! I just loosened the jack and I sliced one end of the rubber washer to where I could slide it over the jack. I then retightened the jack and that's was all. It just pushed the jack end out enough to where the G10 transmitter would fit correctly. 2 Quote Share this post Link to post Share on other sites
jbuhajla 326 Posted January 17, 2017 Perfect. Sometimes you just have to get a little creative. Quote Share this post Link to post Share on other sites
jmartin1997 0 Posted April 14, 2018 On 1/17/2017 at 10:14 AM, Jaret said: Can you post a picture of inside the back plate where you placed the washer? This is genius! I did the same thing with a couple of #10 rubber o-rings from the plumbing isle at home depot. It took me longer to remove and replace the back plate than it did to do the fix. Thanks for the idea. Genius. I was really worried about dinging up the wood around the area, and this fix actually gives me clearance. Quote Share this post Link to post Share on other sites
daviddlch 0 Posted July 13, 2018 On 8/18/2016 at 7:31 AM, KuRiXY said: Exactly, you just bought the opposite, you need mono to stereo or mono to mono :) But not stereo->whatever, or the unit will think it is charging :) When you said mono to stereo are you saying 1/4" mono male to 1/4' stereo female? Quote Share this post Link to post Share on other sites
ozmo 2 Posted October 20, 2019 Thanks @crm3550 and @jmartin1997!! I bought a box of #10 o-rings from the plumbing isle at Home Depot, and followed your steps. It worked perfectly! Here's some reference pics for anyone else wondering. 1 1 Quote Share this post Link to post Share on other sites
daviddlch 0 Posted October 21, 2019 Will this Danco #10 O-ring 11/16" O.D X 1/2 I.D X 3/32" work on Ibanez SR2605 ? Quote Share this post Link to post Share on other sites
ozmo 2 Posted October 21, 2019 4 hours ago, daviddlch said: Will this Danco #10 O-ring 11/16" O.D X 1/2 I.D X 3/32" work on Ibanez SR2605 ? I'm guessing that input jacks are standard, so my money would be on yes. Quote Share this post Link to post Share on other sites
tmerry 0 Posted November 14, 2019 On 10/20/2019 at 1:53 PM, ozmo said: Thanks @crm3550 and @jmartin1997!! I bought a box of #10 o-rings from the plumbing isle at Home Depot, and followed your steps. It worked perfectly! Here's some reference pics for anyone else wondering. Brilliant Idea, thanks for the detailed Pics. I'm going to look at trying that on my JEM77FP. Quote Share this post Link to post Share on other sites
JACB 0 Posted July 3, 2020 On 10/12/2016 at 4:46 PM, crm3550 said: I found a workaround on the transmitter not fitting into the guitar input. I have a Ibanez S series with the recessed 1/4" plug. I removed the back plate lossened the jack and placed a 1/4" thick by 3/4" diameter rubber washer on the outside of the jack. This gave plenty of room for the G10 transmitter to connect. Absolutely brilliant. I was concerned with this because I wanted to buy an Ibanez 224AZ and I didn't think the G10 transmitter would fit in the guitar. So after seeing your post I went to the shop to try the guitar. We checked it with a Boss WL transmitter that didn't fit either. I got the guitar, bought some rings and... Perfect. I can't figure a better solution. I just needed one ring (maybe I'll put one more). It works with both G10 and WL. Thank you very much! Quote Share this post Link to post Share on other sites
crm3550 6 Posted July 3, 2020 I’m glad it worked great for you also. Quote Share this post Link to post Share on other sites
