thanhbeo123 Posted August 17, 2016 Share Posted August 17, 2016 Hi all, I'm a new guy here to POD HD500X. I've downloaded some new tones from Customtone but have no idea how to transfer these tones to my PodHd 500X. There are so many softwares on the website and I don't know what should I have. What are the best (important) softwares do I really need to start with? Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 17, 2016 Share Posted August 17, 2016 You need a program called HD500X Edit. You can find it in the Downloads section of this website. Or you can run Line 6 Monkey with your HD500X connected to your computer via USB. The Monkey will help you download and install it. Monkey will also let you know if you need to update your drivers. Quote Link to comment Share on other sites More sharing options...
BillBee Posted August 17, 2016 Share Posted August 17, 2016 Depending on your OS choose the matching one too. 9/10 there should be no issues but if there are the solutions can generally be found in a forum thread. So no kicking anything! :) Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted August 17, 2016 Share Posted August 17, 2016 I vote for Monkey, not just the EDIT program. Monkey will (when ran) inform you when updates are available. **Speaking of updates: I am going to suggest that you get the latest firmware for your Pod before you bother with installing tones. 1 Quote Link to comment Share on other sites More sharing options...
BillBee Posted August 17, 2016 Share Posted August 17, 2016 That's a good idea PG gave you. If (or should I say when) you get the model packs you will already have the firmware installed (& global eq too btw). Quote Link to comment Share on other sites More sharing options...
skybone Posted August 19, 2016 Share Posted August 19, 2016 Another vote for Line6 Monkey & HD500x Edit, however for either to work, you also need to download the drivers, so that the respective USB ports can talk to one another. Unfortunately, just plugging your HD500x into your PC doesn't work (well, it didn't on my PC). The PC recognizes that something's there, but not what it is. You have to go to the Downloads page and select which software you need for your device & the OS you're running. http://line6.com/software/index.html Quote Link to comment Share on other sites More sharing options...
joel_brown Posted August 19, 2016 Share Posted August 19, 2016 Line6 Monkey is the first piece of software you need to download, install, and run. Quote Link to comment Share on other sites More sharing options...
duncann Posted August 19, 2016 Share Posted August 19, 2016 You actually don't need Line 6 Monkey for anything other than flashing the firmware. It's just the easiest all in one location to tell you what you need which are the drivers, which allow for recording in your daw via usb using asio and also enables using hd edit, hd edit if you want to edit patches on the computer, and the license manager for authorizing any model packs. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted August 19, 2016 Share Posted August 19, 2016 Of the options that Monkey gives you to download direct from the interface, you do NOT need: Variax Workbench Workbench HD Everything else is either a NEED or a HIGHLY RECOMMENDED Quote Link to comment Share on other sites More sharing options...
thanhbeo123 Posted August 23, 2016 Author Share Posted August 23, 2016 Dear all, I'd like to say a BIG THANK YOU for your time and advice. I've got everything that I need (y) Quote Link to comment Share on other sites More sharing options...
