Gkf9 Posted August 26, 2016 Share Posted August 26, 2016 Does it still work in Modelling mode? Many thanks. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted August 26, 2016 Share Posted August 26, 2016 Yes Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted August 26, 2016 Author Share Posted August 26, 2016 Great thanks, need to learn how to do them now. Quote Link to comment Share on other sites More sharing options...
Bertokia Posted August 26, 2016 Share Posted August 26, 2016 It helps to turn your pick so you are pinching the string with the edge of the pick, also try pinching at different positions up & down the string to create varying harmonic notes to jump out... Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted August 26, 2016 Author Share Posted August 26, 2016 Managed to get a few weak one's to squeal a little, took me quite a few try tho. Suppose it all comes down to practice. Quote Link to comment Share on other sites More sharing options...
Bertokia Posted August 26, 2016 Share Posted August 26, 2016 It really helps to use lots of gain/overdrive on yer amp Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted August 26, 2016 Author Share Posted August 26, 2016 Ok thanks, yeah been trying to learn some comfortable numb,Floyd. A few pinch hamonics in the solo.And yes lots of gain hopefully will help. I'm only a beginner tho. Quote Link to comment Share on other sites More sharing options...
Rocco_Crocco Posted August 27, 2016 Share Posted August 27, 2016 It takes a lot of practice play pinch harmonics consistently. Keep at it and eventually you'll be able to play them at will. Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted August 27, 2016 Author Share Posted August 27, 2016 It takes a lot of practice play pinch harmonics consistently. Keep at it and eventually you'll be able to play them at will.That's good to hear, I've probably hit one out of 100 so far. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted August 29, 2016 Share Posted August 29, 2016 I've also found that with the Variax's, it depends alot on where up or down a string you do them. I remember on my old Varaix 500, If I pinched over where the edge of the pickguard was, I was a lot more successful. So experiment with different positions up and down the string, Quote Link to comment Share on other sites More sharing options...
clay-man Posted August 30, 2016 Share Posted August 30, 2016 Pinch harmonics honestly has nothing to really do with anything other than technique of knowing where the divisions are on the string to make a harmonic ring. In order to do pinch harmonics well, you must have a general concept of what you're even doing in the first place. Basically a pinch harmonic is a division of the normal note that would play if you didn't pinch the string. Your thumb hits the string on a hot spot which is divisible on the string. If you did a pinch harmonic at the 12th fret on an open string, it would play the same note as the 12th fret even though you didn't fret down on it, because it's an octave higher, or 1/2 the string length. The only factor you can really say about magnetic vs piezo, is that the magnetic pickups might be a bit more audible in pinch harmonics because of where the pickups sit, but ultimately you can still do pinch harmonics fine on the Variax. 1 Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted August 30, 2016 Author Share Posted August 30, 2016 Thanks Clay man. Quote Link to comment Share on other sites More sharing options...
