GeorgePotter 0 Posted December 31, 2016 Hello. I watched the line 6 video on how to record through a firehawk, but I need more help. Can you please tell he how to setup the recording on a windows 10 pc and which free recording software to download and use (UK). The guitar I'm using is a variax standard. Quote Share this post Link to post Share on other sites
adith_evil 0 Posted August 5, 2017 hey, i have same problem too. i dont know how it works :( Quote Share this post Link to post Share on other sites
Dehzzyy 2 Posted August 5, 2017 Connect Firehawk to USB, make sure you have all drivers installed. I recommend downloading "Reaper" a free to try software that only costs 60$ if you decide you want to pay for it. There is no time limit on the free version and paying for it doesn't unlock anything, so it's an honor system (I paid for it after about a year of fiddling). Once you install Reaper, open it up, and make sure your FIrehawk is set as the audio interface. There are YouTube videos that explain how to do that. 1 1 Quote Share this post Link to post Share on other sites
Dino413 0 Posted February 26, 2018 I have had the same problem with android on a S8+ tried to record with numerous apps could not record threw usb. Just about gave up then decided to try Soundcamp which is a Samsung app. And walla happy camper here. Hope this helps those with similar issues..😠Quote Share this post Link to post Share on other sites
FRS777 0 Posted April 12, 2018 Recording quality on USB. It is written that it is 24 bit, but what more? Is it 192 khHz or less? Is the usb a good interface or should i get another one like apogee to get the best recording sound Quote Share this post Link to post Share on other sites
schedule80 0 Posted June 3, 2018 On 2/25/2018 at 10:47 PM, Dino413 said: I have had the same problem with android on a S8+ tried to record with numerous apps could not record threw usb. Just about gave up then decided to try Soundcamp which is a Samsung app. And walla happy camper here. Hope this helps those with similar issues..😠How do you record the Firehawk FX through Soundcamp? Quote Share this post Link to post Share on other sites
pipelineaudio1 13 Posted June 3, 2018 For reaper, assuming windows: (and depends on how you want to monitor, Firehawk drivers are absolute pieces of total crap compared to POD drivers, which aren't great, but are much more functional) Install Firehawk Software Plug your Firehawk outs to your studio monitors Open REAPER, click the sample right indicator at the top right corner (might show "audio device closed" or similar instead of a sample rate, depending) Chose Audio System ASIO Chose ASIO Driver Firehawk ASIO Drivers Close preferences Right click in the left track control panel area (TCP) and chose Insert new Track (or click menu insert new track) Click the round red button (assuming stock theme) in the new track to arm the track. Don't bother turning on the monitoring icon, Firehawk drivers are total crap and won't allow you to disable direct monitoring in the hardware. Get used to the idea that you have no confidence monitoring or the ability to record the unprocessed input while monitoring the DAW's processing Hit record on the transport, upload your hit song to Distrokid and be the envy of your peers Quote Share this post Link to post Share on other sites
SeaGarath77 0 Posted January 26, 2020 On 6/3/2018 at 8:03 PM, pipelineaudio1 said: For reaper, assuming windows: (and depends on how you want to monitor, Firehawk drivers are absolute pieces of total crap compared to POD drivers, which aren't great, but are much more functional) Install Firehawk Software Plug your Firehawk outs to your studio monitors Open REAPER, click the sample right indicator at the top right corner (might show "audio device closed" or similar instead of a sample rate, depending) Chose Audio System ASIO Chose ASIO Driver Firehawk ASIO Drivers Close preferences Right click in the left track control panel area (TCP) and chose Insert new Track (or click menu insert new track) Click the round red button (assuming stock theme) in the new track to arm the track. Don't bother turning on the monitoring icon, Firehawk drivers are total crap and won't allow you to disable direct monitoring in the hardware. Get used to the idea that you have no confidence monitoring or the ability to record the unprocessed input while monitoring the DAW's processing Hit record on the transport, upload your hit song to Distrokid and be the envy of your peers what do you mean by install the firehawk software, is it the app. Also AS10 Driver Firehawk thing doesn't come up, im totally lost Quote Share this post Link to post Share on other sites
silverhead 8,807 Posted January 27, 2020 3 hours ago, SeaGarath77 said: what do you mean by install the firehawk software, is it the app. Also AS10 Driver Firehawk thing doesn't come up, im totally lost He means the Line 6 Driver for Firehawk. You'll find it in the Downloads section of this website. Select Firehawk FX in the Hardware field and Drivers in the Software field. Quote Share this post Link to post Share on other sites
chief_wigam 0 Posted January 31, 2020 I also don't have any drop down option showing " ASIO Driver Firehawk ASIO Drivers. " My set up is Firehawk to laptop (Windows) using USB cable. Headphones connected into FHFX (no studio monitors). Can somebody please clarify how to connect the Firehawk into Reaper please? Quote Share this post Link to post Share on other sites
silverhead 8,807 Posted January 31, 2020 First you need to have the Line 6 driver installed. You will find it in the Downloads section of this website (see top of this page). On the Downloads page select Firehawk FX in the Products field and Drivers in the Software field. Download and run the driver installer. After installing the driver and connecting your Firehawk FX to your computer via usb the Firehawk FX device and its ASIO driver should appear by default as the active audio device in Reaper. If not you will need to manually select it in the Reaper Preferences. Quote Share this post Link to post Share on other sites
chief_wigam 0 Posted February 1, 2020 Yes I am in Reaper preferences but Firehawk doesn’t appear when choosing ASIO as the Audio System. It only appears when choosing one of the following: WDM Kernel Streaming (Windows 10) direct sound WASAPI (Windows 7/8/10/Vista) waveout i understood I had to choose ASIO should I be choosing one of the other 4 above? thanks in advance Quote Share this post Link to post Share on other sites
chief_wigam 0 Posted February 1, 2020 Ok I downloaded a driver update v1.91 and Reaper now recognises Firehawk under the ASIO selection. Thanks Quote Share this post Link to post Share on other sites
