coachz Posted August 9, 2017 Share Posted August 9, 2017 Is there a way to set pan on the left and right outputs? If you have stereo patches but the PA has poor dispersion, can you reduce the spread or even make them mono? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 9, 2017 Share Posted August 9, 2017 If you only use one of the XLR or 1/4" outs, the signal is automatically summed to mono. There is no global control for pan other than that. Quote Link to comment Share on other sites More sharing options...
coachz Posted August 9, 2017 Author Share Posted August 9, 2017 If you only use one of the XLR or 1/4" outs, the signal is automatically summed to mono. There is no global control for pan other than that. Ahh, that's very nice. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
robbieb61 Posted August 9, 2017 Share Posted August 9, 2017 If you only use one of the XLR or 1/4" outs, the signal is automatically summed to mono. There is no global control for pan other than that. So it's NOT just the Left output that is mono the way it's physically marked on the back of the Helix? Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted August 9, 2017 Share Posted August 9, 2017 So it's NOT just the Left output that is mono the way it's physically marked on the back of the Helix? Â According to the manual, it is in fact only the Left output. I've never tested it, but Phil M is really... never wrong... so... maybe... Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 9, 2017 Share Posted August 9, 2017 So it's NOT just the Left output that is mono the way it's physically marked on the back of the Helix? Â According to the manual, it is in fact only the Left output. I've never tested it, but Phil M is really... never wrong... so... maybe... Â I believe it works identically for whichever one you use, but I can't say I've ever tested it. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted August 9, 2017 Share Posted August 9, 2017 I believe it works identically for whichever one you use, but I can't say I've ever tested it. Â Dude, if YOU are wrong about this... I just can't... go...ON>>>>>>>> Quote Link to comment Share on other sites More sharing options...
coachz Posted August 9, 2017 Author Share Posted August 9, 2017 I don't see anything in the manual about summing. Can someone setup a delay on left and a flanger on right and see what comes out of the left output? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 9, 2017 Share Posted August 9, 2017 I don't see anything in the manual about summing. Can someone setup a delay on left and a flanger on right and see what comes out of the left output? Â It definitely sums to mono when you only use the left XLR or 1/4" output. Here's a post where DI, the product manager, confirms it... Â http://line6.com/support/topic/14264-helix-faq/page-18?do=findComment&comment=110167 Quote Link to comment Share on other sites More sharing options...
coachz Posted August 9, 2017 Author Share Posted August 9, 2017 Sounds like it will do it. Maybe someone can confirm with a trivial test. Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted August 10, 2017 Share Posted August 10, 2017 I can absolutely confirm the Left outputs sum to mono as I use it all the time that way. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted August 10, 2017 Share Posted August 10, 2017 Current 2.0 manual, p. 7, 25 and 26. It's clear it sums to mono. Quote Link to comment Share on other sites More sharing options...
coachz Posted August 10, 2017 Author Share Posted August 10, 2017 Thanks guys. Great info Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted August 10, 2017 Share Posted August 10, 2017 It does. I have my main presets set up as stereo, but currently only go mono to FOH at church. If you are uncertain or just want the added comfort, put in a mono simple EQ block at the end of your chain with it set flat. That will sum your signal to mono before it goes out. Quote Link to comment Share on other sites More sharing options...
coachz Posted August 10, 2017 Author Share Posted August 10, 2017 It does. I have my main presets set up as stereo, but currently only go mono to FOH at church. If you are uncertain or just want the added comfort, put in a mono simple EQ block at the end of your chain with it set flat. That will sum your signal to mono before it goes out. Â That would require modifying every patch right? I'm looking for a way to do it globally and it sounds like the jack does this. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted August 10, 2017 Share Posted August 10, 2017 That would require modifying every patch right? I'm looking for a way to do it globally and it sounds like the jack does this. Correct. Just use the left output and you are good to go. Â Quote Link to comment Share on other sites More sharing options...
