supertonic_jack
Help! Cannot Reinstall JTV Flash memory
Check the Knowledge Base regarding that. Make sure you have the battery plugged in.
It's to engage the battery during the update.
ah somehow the screenshot was removed. bravo!^^
of course i plugged in a 1/4 " cable in order to turn the guitar on. well the factory reset (as described in the manual) didn't work either. a line 6 employee told me that it is not possible anymore for the jtv-89f i got (>wtf line6?)
well but i found the solution to the reinstallation problem with the flash memory. I put the usb interface from the varaix into a usb hub and not the usb port directly (again > WTF LINE 6???).
so my advice for everybody having issues with the line 6 monkey and updating >>> try other usb ports ;)
Factory reset is done by re-Flashing the guitar using Line 6 Monkey.
http://line6.com/support/page/kb/_/guitars/jtvvariax-reflash-and-software-update-instruct-r309
Do not use USB hubs when connecting to Line 6 products.
Well yes, but why did it work over the hub and not directly?
And how can I upload a screenshot here in this forum? how??
I want to show you the error message what happens if I plug in the Variax USB interface directly.
There's a link below in the message frame to upload attachments,
with a 2MB file size limit.
The hub probably has a DC supply. Works with hub,
but not the interface direct,.... odd.
