MarkJarvis Posted November 27, 2017 Share Posted November 27, 2017 Hi All Ok So i am losing my mind trying to get Helix and Variax JTV 69 working. I installed a brand new Windows 10 install and no matter what always get 'The connected Variax is not compatible with Workbench HD. You must use a James Tylers Variax version 2.0 or higher' so I go and disconnect the Variax completely and get the exact same error so it appears that really the message is bogus. I have the supplied VDI cable and have tried several CAT 5 and Cat 5 E cables still always get the same error. Does any know exactly why this doesnt work? Does having Line 6 POD HD 500 installed as well as helix cause this? I did not try uninstalling Line 6 monkey but did disconnect the line 6 POD 500. I just cant figure out how this doesnt work and why my system only FYI Line 6 Support says they have no idea and it 'should work;! Here is my Black Friday recording with 2.30 firmware https://hearthis.at/joejeffries/supermassivemomentum-live-11-24-2017/ help help Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 27, 2017 Share Posted November 27, 2017 Connect the way you normally would for Monkey update or Workbench HD with the the interface device and cables that came with the JTV. Unplug any USB hubs that may be connected. Insert a fully charged JTV battery into the compartment, then plug a stereo headphone adapter into the 1/4" jack. Listen for the click of the relay engaging. There should be two green LED's on the interface device. Check Line 6 Monkey for the Firmware version on the JTV guitar. If it is not v2.00 or higher, Workbench HD will not recognize the guitar. Once all this is completed, you should be able to open Workbench HD. Check the online Pilot's Handbook and the Knowledge Base on this subject for further details if needed. Quote Link to comment Share on other sites More sharing options...
MarkJarvis Posted November 28, 2017 Author Share Posted November 28, 2017 Yeah so everything works witg monkey and the usb interface but with helix nothing..i get tge error..tge firmware for variax is tge latest Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 28, 2017 Share Posted November 28, 2017 Did the battery and the headphone adapter thing? Quote Link to comment Share on other sites More sharing options...
MarkJarvis Posted November 28, 2017 Author Share Posted November 28, 2017 yes Quote Link to comment Share on other sites More sharing options...
MarkJarvis Posted November 29, 2017 Author Share Posted November 29, 2017 Seriously nobody has run into this issue? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 30, 2017 Share Posted November 30, 2017 Use the interface device and cables that came with the JTV-69, and connect to the computer with that, without the Helix. Try that. Quote Link to comment Share on other sites More sharing options...
MarkJarvis Posted December 9, 2017 Author Share Posted December 9, 2017 So for some reason thats not working either which may be a clue Quote Link to comment Share on other sites More sharing options...
jcm4101 Posted December 23, 2017 Share Posted December 23, 2017 Hi.. fwiw, I have a an iMAC and Workbench HD along with HX Edit, JTV and Helix LT Workbench HD is very very intermittent connecting to my JTV, and I get the same message you see.. the one about the software version on the JTV. I've tested various connectivity scenarios and the Workbench HD sometimes connects, sometimes doesn't and sometimes connects then fails to communicate with the JTV when settings are changed.. Currently my chain looks like this.. MAC USB --> Helix LT --> JTV (via the cat 5 cable). This is the most stable connectivity sequence I can get.... dropping out the Helix makes connectivity to workbench worse.. Basically, workbench is useless to me, so the value of it is wasted. I'd like a solution, but it looks like this issue isn't restricted to Windows... it's MAC too.. Help anyone? PS, everything (including the iMAC) is running latest available firmware.. Thanks 1 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 27, 2017 Share Posted December 27, 2017 I recall some odd quirk between JTV and iMac's. I think that got resolved early on, but make sure to add that to your support ticket,... just to be certain that is covered. Quote Link to comment Share on other sites More sharing options...
