New Legacy FX - Duplicates and Not in Helix before...
jaybee77
The following Models have Duplicates as HX Versions and Legacy
(note this doesnt scale up well on the mobile version - use desktop version on a mobile)
Distortion                                         Helix HX                            Legacy
Chandler Tube Driver                      Valve Driver                      Tube Drive
Ibanez® TS808 Tube Screamer®   Scream 808                       Screamer
DOD® OD-250                                  Top Secret OD                  Overdrive
ProCo RAT                                        Vermin Dist                       Classic Dist
Arbiter® Fuzz Face®                       Arbitrator Fuzz                  Facial Fuzz
Electro-Harmonix® Big Muff Pi®   Triangle Fuzz                     Fuzz Pi
Tycobrahe® Octavia                        Tycoctavia Fuzz                Octave Fuzz
Dynamics
Teletronix® LA-2A®                         LA Studio Comp               Tube Comp
MXR® Dyna Comp                           Red Squeeze                     Red Comp
Modulation
Pan / Panner                                     Pan/Volume category    Panner
Vox® AC-15 Tremolo                       60s Bias Trem                    Bias Tremolo
Fender® optical tremolo                 Optical Trem                     Opto Tremolo
MXR® Phase 90                               Script Mod Phase            Script Phase / Phaser
Shin-ei Uni-Vibe®                            Ubiquitous Vibe                              U-Vibe
BOSS® VB-2 Vibrato                       Bubble Vibrato                 Pitch Vibrato
BOSS® CE-1                                    70s Chorus                         Analog Chorus
Dytronics® Tri-Stereo Chorus       Trinity Chorus                   Tri Chorus
MXR® 117 Flanger                           Gray Flanger                     Analog Flanger / AC Flanger
A/DA Flanger                                   Harmonic Flngr                 Jet Flanger / 80A Flanger
Line 6 Original                             AM Ring Mod / Pitch Ring    Ring Modulator
Fender® Vibratone                          Vibe Rotary                       Rotary Drum
Leslie® 145                                       145 Rotary                         Rotary Speaker
Delay
Line 6 Original                                  Ping Pong                          Ping Pong
TC Electronic® 2290                        Ducked Delay                   Dynamic
Line 6 Original                                  Vintage Digital ?               Digital
Line 6 Original                                  Reverse Delay                   Reverse
Maestro® Echoplex EP-3                Transistor Tape                Tape Echo
Line 6 Original                                  Sweep Echo                      Sweep Echo
BOSS® DM-2                                    Bucket Brigade                 Analog Echo
Electro-Harmonix®
Deluxe Memory Man                        Elephant Man                   Analog w/Mod
Roland® RE-201 Space Echo         Cosmos Echo                    Multi-Head
Pitch / Synth
Eventide® H3000                             Twin Harmony                  Smart Harmony
Filter
Musitronics® Mu-Tron® III             Mutant Filter                     V Tron / Tron Up / Tron Down
The following are Legacy effects that werent previously available as HX versions in Helix.
https://line6.com/m13/images/m13_modelgallery02.pdf
Distortion Models - 8
Heavy Dist              BOSS® Metal Zone
Colordrive               Colorsound® Overdriver
Buzz Saw                Maestro® Fuzz Tone
Jumbo Fuzz            Vox® Tone Bender
Jet Fuzz                  Roland® Jet Phaser
L6 Drive                  Colorsound® Overdriver (modded)
L6 Distortion          Line 6 Original
Sub Oct Fuzz          PAiA Roctave Divider
Dynamics Models - 5
Blue Comp              BOSS® CS-1
Blue Comp Treb      BOSS® CS-1 (Treble switch on)
Vetta Comp             Line 6 Original
Vetta Juice             Line 6 Original
Boost Comp            MXR® Micro Amp
Modulation Models -  6-7
Pattern Trem           Line 6 Original
?? Panner                 Line 6 Original - HX version is available in Helix Pan/Volume- ?
Panned Phaser        Ibanez® Flying Pan
Barberpole Phaser  Line 6 Original
Dual Phaser             Mu-Tron® Bi-Phase
Dimension               Roland® Dimension D
Freq Shift               Line 6 Original
Delay Models    -    6/7
Stereo                    Line 6 Original
Dig w/Mod              Line 6 Original
Lo Res                    Line 6 Original
Tube Echo              Maestro® Echoplex EP-1
Echo Platter           Binson® EchoRec®
Auto-Vol Echo        Line 6 Original
Multi-Head             Roland® RE-101 Space Echo (Helix has Cosmos Echo - based on the Roland RE-201 Version, according to the HXFX manual)
Pitch/Synth Models -  6
Bass Octaver           EBS® OctaBass
Octi Synth                Line 6 Original
Synth O Matic        Line 6 Original
Attack Synth          Korg® X911 Guitar Synth
Synth String           Roland® GR700 Guitar Synth
Growler                  Line 6 Original
Filter Models       -  8
Voice Box                Line 6 Original
Q Filter                    Line 6 Original
Seeker                     Z Vex Seek Wah
Obi Wah                  Oberheim® voltage-controlled S&H filter
Throbber                 Electrix® Filter Factory
Slow Filter              Line 6 Original
Spin Cycle              Craig Anderton's Wah/Anti-Wah
Comet Trails           Line 6 Original
Not all legacy FX are available in stereo -
Notes taken from the HXFX manual
https://line6.com/data/6/0a020a3d3f4a5a6a1897ecdf6/application/pdf/HX%20Effects%202.50%20Owners%20Manual%20-%20English%20.pdf
Legacy effects models vary in behavior, just as on the classic Line 6 effects from
where these models originated.
• Legacy Distortion, Dynamics & Pitch/Synth effects are mono.
• Legacy Modulation & Delay effects vary in that some are mono, some stereo,
and some mono-in/stereo-out, where adjusting the effect's Mix parameter
can narrow the stereo image that is fed into them. It is best to experiment
with these effects and tweak the Mix parameter to achieve the desired stereo
output results.
• Legacy Filter and Reverb effects are stereo.
http://line6.com/support/topic/31888-so-legacy-effects-are-always-stereo-mono/?p=244826
http://line6.com/support/page/kb/_/effects-controllers/m5-m9-m13/stereomono-fx-routing-table-r127
http://line6.com/support/index.php?app=core&module=attach&section=attach&attach_id=474
Some Notes On the original Reverbs and Wahs in Helix.
Digital Igloo on The Gear Page
June 12th 2015
At launch, all reverb models are based on HD models, but rebuilt in HX. They sound notably better in Helix tho'. Eight of the ten wahs came from HD as well. All other FX models were created from scratch in HX.
https://www.thegearpage.net/board/index.php?threads/line6-helix.1586637/page-3#post-20130691
july 2nd 2015
We felt that two HX wahs weren't enough, and the eight HD wah models were fairly simple to rebuild in HX (unlike models in other categories).
https://www.thegearpage.net/board/index.php?threads/line6-helix.1586637/page-26#post-20226571
April 8th 2016
The only reason we ported 8 out of 10 wahs and the reverbs from HD (everything else is built from scratch in HX) is because we simply ran out of time. Ideally, everything in Helix would've been brand new. I'm not morally opposed to porting M-Class/HD models to HX, but we'd much rather make new stuff.
https://www.thegearpage.net/board/index.php?threads/digital-igloo-will-the-helix-be-getting-a-full-set-of-synths-and-modulation.1692582/#post-21734256
The 2 HX wahs -
UK and Teardrop.
BenAdrian -  TGP
https://www.thegearpage.net/board/index.php?threads/line6-helix.1586637/page-304#post-23035076
Digital Igloo - TGP
https://www.thegearpage.net/board/index.php?threads/line6-helix.1586637/page-29#post-20267812
The Reverbs and eight of the ten wahs are HD models rebuilt within the HX engine. We also rebuilt Doom, Epic, and Elektrik, but they're favorite custom hybrids that, IIRC, utilize some HX components—will have to confirm?
  • 3 months later...
Nice compilation.
Just to note, even though there's a lot of overlap between HD and HX effects, it's probably not a good idea to automatically assume the HX version is better. A couple of examples might be the script mod phase and the tube driver. To me, the HD versions sound better. And in particular, the HD script mod phase doesn't thin out the tone nearly as much as the HX. There could be others...
  • 7 months later...
Dynamics
Modulation
Delay
Electro-Harmonix®
Pitch / Synth
Filter
Dynamics Models - 5
Delay Models    -    6/7
Filter Models       -  8
output results.
June 12th 2015
july 2nd 2015
April 8th 2016
The 2 HX wahs -
UK and Teardrop.
BenAdrian -  TGP
Digital Igloo - TGP
Are there any plans to add the Boost+EQ booster (line6)?
Quote
This is a user forum... the "official" folks who occasionally make an appearance won't divulge the time of day.
But OTOH they will describe that day for you quite well.  As in "it'll be a cold day in hell before I divulge information here, better go to TGP"... ; )
Thanks, Jaybee for the info!
