japrifer 0 Posted March 1, 2018 Hello. I have been usin Amplifi 75 for some time at home. Now I have to use it in a band and I just can't get enough volume out of it. My friend with a 60W amp sounds great whereas I have to mic my amp. What is the actual power output of the Amplifi 75? How can it be that my guitar doesn´t sound over the drums with a 75W amp? Thanks Quote Share this post Link to post Share on other sites
jdavidboyd 4 Posted March 2, 2018 You have to be certain that you have the sound of the preset turned up, as well as the amplifier volume. Which preset are you using? Is it something you created? Quote Share this post Link to post Share on other sites
spaceatl 1,975 Posted March 2, 2018 If you are playing with another guitarist and you are trying to use a tone with a lot of distortion, you may have overdone it....Scooping mids and diming the drive is the very best to way to not cut thru...If you other guitar player is using a 60 watt tube amp, then he basically has 2-3 times the dynamic range that your SS 75 watt amp has...It will likely never compete with that if that is the case...Anyway, I suspect you are using a super saturated tone and likely don't have enough mids...That is ALWAYS how you cut thru...turn down the drive and turn up the mids until you cut thru...The cleaner it is, be better it will cut thru...Other things can be too much verb and delay.... Quote Share this post Link to post Share on other sites
japrifer 0 Posted March 2, 2018 It happens with my presents and with factory presets as well. Clean tones and overdriven tones. My friend is using a sold state amp. I don't think the issue is related to presets but to the actual power of the amplifi. It is as if the amplifi splits power to the guitar and the backing tracks and half of the power goes to the guitar actually. I'm kind of lost... Quote Share this post Link to post Share on other sites
cbrillow 32 Posted March 7, 2018 Another thing to check is the guitar level in the mix. Press down on the volume knob, which will change the ring of LEDs surrounding it from red to white. When white, you are adjusting the guitar level in the mix that's sent to the output stage. Turn the knob clockwise so that you have a strongest possible signal, then push the knob again to return to the red LEDs and adjust as necessary. Quote Share this post Link to post Share on other sites
Koebi 2 Posted March 7, 2018 Hey, brillow, you just Posted the best ever description of the large Button Quote Share this post Link to post Share on other sites
cbrillow 32 Posted March 7, 2018 Hey, brillow, you just Posted the best ever description of the large Button Thanks for your comment. Just hope I'm right and that it helps others in some way... Quote Share this post Link to post Share on other sites
