alemas
John Petrucci Original FX Preset
i found a picture of Petruccis preset for axe-fx (see attached file).
Now, i have the following questions:
How to achieve a similar signal chain in Helix native?
What effects does he use?
What could be the settings?
I hope someone could help me.
Thank you and best regards,
alemas
This approach is not gonna work very well. Nobody is gonna be able to guess at settings based on a screenshot of a signal chain... and even if you had the settings, they're for a different device... this is a non- starter.
If you don't want to try and create your own patch, then check for Petrucci stuff on Customtone... though in my experience, that's also a long wait for a train that ain't coming. If you really want to learn how to tone-match, you have to experiment. Start with models of gear that he uses... various Boogie amps and cabs, or other high gain amp models that might yield a similar tone.  Get a basic tone first before you start worrying about FX.
I have tone-matched 7 amp sounds. They sound similar to the originals. Now i want to achieve a fx preset.
Hey!
yes that would be great. Is it possible to run the EQ and Vol/Pan in series, then the chorus, pitch and delay in the first path in series in a split-block and in the second path the EQ and Vol/Pan in series, then the delay and the multidelay with reverb in parallel in another split-block
alemas
On 4/11/2018 at 4:36 AM, jbuhajla said:
Multiple parallel paths would be very cool in Helix...
By using both paths 1 & 2 and running a parallel path A & B in each path, you have 4 paths you can use. They are, technically, all parallel but you can't stack them the way Petrucci does. I guess the way to describe it is two parallel paths that are in parallel. Does that make sense?
Great it helps me, so what types of delays are you using ? i have a helix too and my amps simulations are pretty cool but impossible to find a way to have the same type of delays/reverberation of God Petrucci...
