thecameralens Posted April 20, 2018 Share Posted April 20, 2018 For anyone who is unsure of whether you can use the legacy Variax guitars under Windows 10, I can confirm that you can. I went to the download section and just selected Windows 8 as the OS and downloaded Line 6 Monkey and Workbench (non HD version), ran the installers, hooked up my Variax USB Interface and Variax 500 and everything worked perfectly first time. I had no issues with Java or the installation on the drivers. This statement is valid as of April 2018 1 Quote Link to comment Share on other sites More sharing options...
pn2503 Posted April 20, 2018 Share Posted April 20, 2018 I just did the exact same thing and am having an issue with java runtime environment. Did you download Java version 8 after Java timed out? Quote Link to comment Share on other sites More sharing options...
codamedia Posted April 20, 2018 Share Posted April 20, 2018 When you get a JAVA error... just go to java.com and install the latest version. If JAVA complains that it isn't compatible with your browser just ignore it - that won't matter. 2 Quote Link to comment Share on other sites More sharing options...
pn2503 Posted April 21, 2018 Share Posted April 21, 2018 Boom. Did that and it worked- thanks! Quote Link to comment Share on other sites More sharing options...
thecameralens Posted April 21, 2018 Author Share Posted April 21, 2018 8 hours ago, pn2503 said: I just did the exact same thing and am having an issue with java runtime environment. Did you download Java version 8 after Java timed out? I didn’t have a problem with Java at all. I remembered seeing a post about the installer under Windows 10 and just unchecked Java in the installer and let it use the version already installed on my PC. I forgot to mention that step in the original post. Quote Link to comment Share on other sites More sharing options...
codamedia Posted April 21, 2018 Share Posted April 21, 2018 8 hours ago, thecameralens said: ... just unchecked Java in the installer and let it use the version already installed on my PC Just a word of note... this may not work for everyone. Java isn't usually installed on a machine by default... it likely came with a different software installation along the way. 1 Quote Link to comment Share on other sites More sharing options...
thecameralens Posted April 21, 2018 Author Share Posted April 21, 2018 1 hour ago, codamedia said: Just a word of note... this may not work for everyone. Java isn't usually installed on a machine by default... it likely came with a different software installation along the way. That is a good point Quote Link to comment Share on other sites More sharing options...
cbrillow Posted April 24, 2018 Share Posted April 24, 2018 Good information for now and the future. Would like to see this made a 'Sticky'.... Quote Link to comment Share on other sites More sharing options...
insulan Posted September 2, 2018 Share Posted September 2, 2018 I can not find any Workbench other than the HD, that is a problem... Not under legacy product either Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 4, 2018 Share Posted September 4, 2018 Both versions should be in the "Downloads" page under the Support link. Quote Link to comment Share on other sites More sharing options...
codamedia Posted September 7, 2018 Share Posted September 7, 2018 On 9/2/2018 at 10:58 AM, insulan said: I can not find any Workbench other than the HD, that is a problem... Not under legacy product either If you are looking for the older version of Workbench on the Line 6 site it won't show up if you limit the OS to Windows 10 in the search. Change the OS to Windows 7 and it will show up... even though it works fine in Windows 10. 1 Quote Link to comment Share on other sites More sharing options...
