aggravation Posted December 17, 2013 Share Posted December 17, 2013 I think I need to put a spacer inside the post hole in my knob so that the switch isn't so hard to engage. How do you remove the knob to do this? Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 17, 2013 Share Posted December 17, 2013 You lift it off, or pry it carefully if necessary. There are no fasteners; it's strictly pull/push to take it off/on the shaft in the center of the knob. Quote Link to comment Share on other sites More sharing options...
clay-man Posted December 17, 2013 Share Posted December 17, 2013 I took mine off easily, the only problem I had was that the knob kept rising up past the plastic notch it has on it so I put a LITTLE bit of glue on it to hold it down afterwards. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted December 17, 2013 Share Posted December 17, 2013 Use two spoons and a towel. Put the end of each spoon opposite each other under the edge of the knob with a towel underneath to protect the instrument. Then just lever (pry) each side up with the spoons. Hope this makes sense. 2 Quote Link to comment Share on other sites More sharing options...
PANT666666 Posted March 17, 2014 Share Posted March 17, 2014 I just started having trouble with the selector knob as well. The top of the knob (chrome piece) will not stay in the barrel that is the model selector. I don't want to use glue because of the push on/of function could be harmed. Does anyone have any other ideas and possibly a photo or explosion diagram? This is no way for a new $1000 guitar to behave. Elderly instruments will be hearing about this one today! Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted March 17, 2014 Share Posted March 17, 2014 I just started having trouble with the selector knob as well. The top of the knob (chrome piece) will not stay in the barrel that is the model selector. I don't want to use glue because of the push on/of function could be harmed. Does anyone have any other ideas and possibly a photo or explosion diagram? This is no way for a new $1000 guitar to behave. Elderly instruments will be hearing about this one today! Thousand dollar guitar....1/4 cent Chinese plastic knob. You do the math....sucks, but it is what it is. 1 Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 17, 2014 Share Posted March 17, 2014 few tiny drops of super glue... its been done a few times by other forum users... not a huge issue.. but it does happen. 1 Quote Link to comment Share on other sites More sharing options...
PANT666666 Posted March 17, 2014 Share Posted March 17, 2014 I approached Elderly instruments and received the following reply: "Our apologies for any trouble with your Variax Guitar. Unfortunately we are no longer a Line6 dealership which is why we were closing out this line of products from our inventory. So we are limited to how we can be of assistance with the knob problem. Still we'll do what we can to help." Note: there is more text - and to their credit, the reply was fast and they offer a return. The never mentioned the closeout due to not being a Line 6 dealer - but that's no big surprise. I went on to ask about the "setup" that all of their guitars are to experience - I was told they put this one through a setup prior to making it a saleable item - I guess its just not the same as the $65 setup my luthier does. At any rate I will do with super glue... Thanks all for your awesome advice. Quote Link to comment Share on other sites More sharing options...
clay-man Posted March 17, 2014 Share Posted March 17, 2014 few tiny drops of super glue... its been done a few times by other forum users... not a huge issue.. but it does happen. high 5. If you put just a little, it'll be enough to hold it in place securely, but just little enough to break off if you ever need to take it off again. I took off my knob and the tab that stops the knob from spinning past custom 1 and custom 2 kept being higher than the obstruction so I used super glue to make sure the knob stopped rising up past that point again. Quote Link to comment Share on other sites More sharing options...
PANT666666 Posted March 18, 2014 Share Posted March 18, 2014 Well... I don't like it. But far be it from me to not take the sage advice of this impressive forum: So - using the super glue gel (allows for micro application) placed three small drops (globs) at 12 , 4 and 7 o clock onto the chrome plated knob insert and placed knob insert into drum formed by the model selector switch - glue set up in a few minutes - tested OK. That should hold it - I hope I never need to remove the knob insert. Remember kids - having a dream rig is scary, but it's never boring. Quote Link to comment Share on other sites More sharing options...
