wcmexbm 5 Posted October 18, 2019 What brand/ type locking tuners that require no drilling would work with the Variax Standard? Looking at these Hip-Shot Grip-Locks, suitable? https://www.amazon.com/gp/product/B00ABLI0IC/ref=ox_sc_act_title_1?smid=A2BFSBLSC4DZ2&psc=1 Quote Share this post Link to post Share on other sites
psarkissian 354 Posted October 18, 2019 Best to go to your local guitar shop or music instrument retailer and compare to see what fits. Quote Share this post Link to post Share on other sites
cruisinon2 2,532 Posted October 18, 2019 3 hours ago, wcmexbm said: What brand/ type locking tuners that require no drilling would work with the Variax Standard? Looking at these Hip-Shot Grip-Locks, suitable? https://www.amazon.com/gp/product/B00ABLI0IC/ref=ox_sc_act_title_1?smid=A2BFSBLSC4DZ2&psc=1 There are several things to consider: 1) The diameter of the hole that the tuner sits in. 2) The position of the mounting screw on the back of the headstock. 3) Some tuners have a small post that protrudes from underneath which serves as an anchor, in lieu of a mounting screw...some older Sperzel tuners had these. This would require drilling a small hole to accommodate the post. This is less likely to be the case though, as the ones you picked clearly have a mounting screw. #2 is often a problem. Even if they otherwise fit, the position of the mounting screws is not universal... they can be anywhere. You'd have to see if the ones you want have that mounting screw in the same position as the stock ones...if the stock ones have them at all. If not, you'll be drilling and/or filling holes. Quote Share this post Link to post Share on other sites
psarkissian 354 Posted October 18, 2019 Also, be sure the strings have a 12 to 15 degree breaking angle between the string nut and tuner post hole. Quote Share this post Link to post Share on other sites
Cloud_Runner 0 Posted April 4, 2020 This is probably a bit late for everyone, but I just changed my machine heads for Schaller M6 locking machine heads with pin mount and a locking post length of 21.0mm. They were a perfect fit with no mods necessary. https://schaller.info/en/m6-series/272/m6-pin?number=10030220.01.53 Quote Share this post Link to post Share on other sites
soundog 489 Posted April 4, 2020 I bought a set of AllParts locking tuners (Part No. TK-7591-010) for $35 online. They fit like a glove, swap out in minutes, and are working nicely. I used the original washers from the Variax because I like the bevel on them better than the ones provided. Sure, there are better locking tuners out there, but these are a nice match for my Standard. Quote Share this post Link to post Share on other sites
mattfrantz 0 Posted May 3, 2020 Thanks for those that posted parts that work. I've been thinking about putting locking tuners on my Variax standard and like the auto-trim feature of the Planet Waves version, but am not sure if I would need to modify the hole diameter. Also for those of you using the locking tuners, have you had issues with the high E and B strings slipping out? I use .09 gauge and have a set of Billy Gibbons .07 I want to try but I've read that the lighter gauges can slip through some brands unless they are double-looped through the tuner. Quote Share this post Link to post Share on other sites
