Good day dear Line6 and everyone!!
Q.1
I have POD X3 and POD HD Bean.
I connect them to two KRK monitors through this mixer:
www.rjmmusic.com/mini-line-mixer
Please tell me which 6.3jack cables I need to use to operate one POD in stereo and where to connect them? 2 TRS or 2 TS? If I connect one or two cables, which inputs are should I use the mixer in these two separate cases? Please read the instructions for the mixer. I look forward to hearing from you, with respect.
I'm playing through GearBox.
Q.2
What cables should I use from this list to connect two monitors to the mixer?
I also want to inform you that the engineer from RJM who produced this mixer advised me to use 2 mono-jack cables to
mono-xlr (ground connected to sleeve in xlr-connector).
But I want to ask you, it will be the right option if I do not have grounding in the outlet and whether there will be noise from ground fault with sleeve on every cable?
If there is another connection option from the list, then please inform me of the best option.
All in two photos.
Q.3
How to adjust the impedance on this sound path? (Guitar Processor> Mixer> Monitors) What value should not exceed and not be underestimated at the inputs and outputs. Give an example please (Guitar processor> Mixer> Monitors).
Mini Line Mixer Manual.pdf
MLM-1 Example.pdf
Q.1
Q.2
All in two photos.
Q3.
What cables should I directly connect the left and right outputs from the POD to the two monitors in the XLR inputs on the monitors,
TS> XLR or TRS> XLR?
Q4.
Are the outputs and inputs identical in the POD HD Bean and POD X3?
Q5.
Can I connect a second guitar to the second input and how best to do it?
Q6.
How to set TRIM value and what is its role in the processor?
Q7.
Why is there no instruction for POD HD bean in Russian or other languages?
Q8.
How to adjust the impedance on this sound path? (Guitar Processor> Mixer> Monitors and Guitar Processor> Mixer> Studio headphones) What value should not exceed and not be underestimated at the inputs and outputs. Give an example please (Guitar processor> Mixer>Monitors).
Q9.
Do I need to remove the cables from the outputs on the processors, if I decide to play with headphones? Will it negatively affect the sound?
MLM-1 Example.pdf
Create an account
Register a new account
Sign in
Sign In Now
