futurepr0n Posted November 22, 2019 Share Posted November 22, 2019 Hey all, I just bought a new MacBook to start getting back into using my Line 6 Pod X3 Live and was going to start installing the drivers and software and stuff, but it looks like Line 6 Monkey does not install on this version of OSX. Is there a way for me to run the installer? I managed to get Line 6 License Manager no problem. But for some reason I can't get this. Is there any further support for software on this pedal? 1 Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted November 23, 2019 Share Posted November 23, 2019 Did you try manually downloading everything from line6.com? You dont need monkey, its just convenient. Its all on the downloads section at line6.com Quote Link to comment Share on other sites More sharing options...
futurepr0n Posted November 26, 2019 Author Share Posted November 26, 2019 I tried, Line6 Monkey installs, but won't run because its built for 32 bit and my Mac OS is the latest, which only supports 64bit apps. I installed the driver manually, which "works", however the Line 6 X3 Live is not found in Mac OSX Catalina, and I can't record any audio through Ableton, it also doesn't come up as a device. Is there a 64 bit version of the driver to be made available sometime??? Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted November 27, 2019 Share Posted November 27, 2019 https://line6.com/support/announcement/98-macos-1015-catalina-compatibility/ Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted November 27, 2019 Share Posted November 27, 2019 Sounds like you need to download and install the latest 64-bit version Quote Link to comment Share on other sites More sharing options...
futurepr0n Posted December 18, 2019 Author Share Posted December 18, 2019 The only part is there isn’t any 64bit version of anything. the Catalina article says the drivers should still work, but after installing the drivers I still cannot see it access my device in OS X for recording - it is not recognized at all as a sound input or output device at the OS level, nor at any other level, it’s not available as an option in GarageBand, or ableton. the pedal is useless on Catalina and that’s a major bummer. I got a new MacBook Pro, there is no option to revert back to an older OS version. please guys, help us out. I can’t buy a new pedal for this purpose alone, it’s simply not possible within my budget. Everything works in windows 10 fine, however Catalina/OS X is my preferred OS and i can’t be the only user or affected. Is there any technical support tech that could troubleshoot over the phone? I would require someone who has a similar set up or access to the same products. Quote Link to comment Share on other sites More sharing options...
Skipernicus Posted February 21, 2020 Share Posted February 21, 2020 It's been at least 6 months. Where is the update? I have 4 Variax guitars in this studio, and workbench DOES NOT WORK. Quote Link to comment Share on other sites More sharing options...
jbsancho Posted March 31, 2020 Share Posted March 31, 2020 Does anyone know if an update has been released from Line6 regarding this issue with OS Catalina? I'm experiencing the same problem. My MacBook doesn't recognise the UX2. I was able to install the License Manager and the drivers (which are not recognised by the OS either) and Line6 Monkey is just not compatible with the OS. This is really a pain... Do you guys know a trick or something to be able to use the pod in the meanwhile (and if so) Line6 releases a new update of Monkey ? Quote Link to comment Share on other sites More sharing options...
Revjones Posted April 1, 2020 Share Posted April 1, 2020 It is not like the move to 64bit-only wasn't in the air for many months already, if not years. How come most of the other developers managed to properly anticipate it and update their apps accordingly? Line 6's is not exactly free stuff, either. Another otherwise fine device to throw into the junk box. That's a pity. Quote Link to comment Share on other sites More sharing options...
Colton165 Posted April 4, 2020 Share Posted April 4, 2020 hopefully someone has found some resolution to this??? I recently got rid of my old windows computer and got a new MacBook... trying to use my Pod x3 Live with it.. Quote Link to comment Share on other sites More sharing options...
dchristensen11 Posted April 19, 2020 Share Posted April 19, 2020 so where do I get the 64bit versions? Tried all the latest installers and they are all installing Line 6 monkey 32-bit. can use POD HD500 with my Mac Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 19, 2020 Share Posted April 19, 2020 4 hours ago, dchristensen11 said: so where do I get the 64bit versions? Tried all the latest installers and they are all installing Line 6 monkey 32-bit. can use POD HD500 with my Mac There isn’t a 64-bit version of Monkey. Quote Link to comment Share on other sites More sharing options...
alanross Posted April 22, 2020 Share Posted April 22, 2020 Similar issue. I have Catalina and want to use my UX1 in GarageBand. Anyone know how to fix this yet? Quote Link to comment Share on other sites More sharing options...
ADobie Posted April 22, 2020 Share Posted April 22, 2020 Finally I have my Pod X3 Live working on Catalina :) Uninstall exisiting driver using the Line 6 Driver Uninstaller app, then: Launch the Terminal application and type the following commands at the prompt: sudo pkgutil --forget com.line6.driver.xtaudio.package sudo pkgutil --forget com.line6.driver.xtmidi.package Then Reboot mac Disconnect the X3 live (I think this may be crucial as I went through the process without doing this and it did not work) Install the latest driver (7.6.8) Reboot mac Opened the driver config screen via system preferences Reconnected the X3 and there it is. Can now use Garage Band etc. 1 Quote Link to comment Share on other sites More sharing options...
fatherstew Posted April 29, 2020 Share Posted April 29, 2020 Is Line 6 just going to remain quiet on this topic??? I've been able to run my Line 6 X3 Live since I upgraded to Catalina but I no longer have access to updates for it as there is no Line 6 Monkey available. The last thing said on this from Line 6 was that you are working on a solution. Line 6 should've been advised in advance by Apple that they were no longer supporting 32-bit software but here we, 6 months after the fact, and there is still solution or response. I've always appreciated the fact that Line 6 has been still supporting older equipment, as I certainly can't afford to upgrade, but is this Line 6's way of doing Apple's thing and forcing people to buy new equipment as it is no longer supported??? Some response would be better then nothing! Regards. Quote Link to comment Share on other sites More sharing options...
ckmpod Posted May 3, 2020 Share Posted May 3, 2020 Come on Line 6.... Get your act together, we got music to make here. We need 64bit to run with Catalina and our DAWS!!!! POD Studio UX1 registered user Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 3, 2020 Share Posted May 3, 2020 3 hours ago, ckmpod said: Come on Line 6.... Get your act together, we got music to make here. We need 64bit to run with Catalina and our DAWS!!!! POD Studio UX1 registered user Monkey doesn't work with Catalina and probably will never be updated to 64-bit. But the drivers for the UX1 should be compatible with Catalina. What are you having issues with? Quote Link to comment Share on other sites More sharing options...
ckmpod Posted May 3, 2020 Share Posted May 3, 2020 Well thank you getting back to me. I hope we can resolve this. Its a synchronising issue between audio and midi. I've downloaded the latest update after updating system to Catalina and Garageband to the latest upgrade. I've tried looking for conflicts but it must be that the 24bit is conflicting with the 64bit. Your advise will be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
ckmpod Posted May 3, 2020 Share Posted May 3, 2020 10 minutes ago, ckmpod said: Well thank you getting back to me. I hope we can resolve this. Its a synchronising issue between audio and midi. I've downloaded the latest update after updating system to Catalina and Garageband to the latest upgrade. I've tried looking for conflicts but it must be that the 24bit is conflicting with the 64bit. Your advise will be greatly appreciated. 10 minutes ago, ckmpod said: Well thank you getting back to me. I hope we can resolve this. Its a synchronising issue between audio and midi. I've downloaded the latest update after updating system to Catalina and Garageband to the latest upgrade. I've tried looking for conflicts but it must be that the 24bit is conflicting with the 64bit. Your advise will be greatly appreciated. Its the driver I installed Quote Link to comment Share on other sites More sharing options...
ct400b1 Posted May 17, 2020 Share Posted May 17, 2020 Same problem here. I bought a brand new Macbook Pro, Variax and Helix Native thinking I would be good to go and ready to play. Nope! The hardware is working just fine but Workbench and Monkey will not work with Catalina and there's nothing I can do about it. Line 6 apparently could care less because this has been an issue for a very long time and they have done nothing to correct this issue. They have no problem selling you their products but will leave you hanging when your equipment is basically non functional for what you would like to use it for. They say that they are working on it but I doubt that they are being truthful. It's very dissapointing to me. I expected much better after spending so much money. Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 17, 2020 Share Posted May 17, 2020 2 hours ago, ct400b1 said: Same problem here. I bought a brand new Macbook Pro, Variax and Helix Native thinking I would be good to go and ready to play. Nope! The hardware is working just fine but Workbench and Monkey will not work with Catalina and there's nothing I can do about it. Line 6 apparently could care less because this has been an issue for a very long time and they have done nothing to correct this issue. They have no problem selling you their products but will leave you hanging when your equipment is basically non functional for what you would like to use it for. They say that they are working on it but I doubt that they are being truthful. It's very dissapointing to me. I expected much better after spending so much money. Workbench HD should work with Catalina. The original Workbench is 32-bit only, and will not. As far as Monkey, it's ancient software at this point. Line 6 has continued to support it only because there are a few hardware SKUs that still use it, the Variax being one of them. I'm nearly certain that instead of trying to update Monkey to 64-bit, that what Line 6 is going to do is going to make it so Line 6 Updater supports the Variax. I mean the thing with this Catalina thing is that is was entirely a decision that Apple made that caused the issue. Apple dropped 32-bit entirely with Catalina, so it's puts the burden on other companies to react. Say what you want about Windows, but Windows 10 still support 32-bit software. Quote Link to comment Share on other sites More sharing options...
ct400b1 Posted May 22, 2020 Share Posted May 22, 2020 Phil_m, I appreciate the info. You are correct and I am humbled. Needless to say, I was frustrated and since I wrote that, I was able to get Workshop HD up and running. My Variax is now able to connect and I can make the adjustments I need. Thank you so much for helping me. I had to download the newest version. My apologies to everyone for venting my frustration. Quote Link to comment Share on other sites More sharing options...
LudvikHusek Posted June 4, 2020 Share Posted June 4, 2020 Is there a way I can update firmware in my Relay G90s with Catalina? Quote Link to comment Share on other sites More sharing options...
pcosmo Posted July 10, 2020 Share Posted July 10, 2020 I had this problem, the issue wasn't that the Mac security was not allowing the drivers to be loaded. To fix this: https://line6.com/support/page/kb/recording/computer-audio-set-up-and-troubleshooting/macos-high-sierra-1013mojave-1014catalina-1015-driver-installation-change-r879/ 1 Quote Link to comment Share on other sites More sharing options...
icorra Posted July 22, 2020 Share Posted July 22, 2020 On 5/17/2020 at 7:51 PM, phil_m said: Workbench HD should work with Catalina. The original Workbench is 32-bit only, and will not. As far as Monkey, it's ancient software at this point. Line 6 has continued to support it only because there are a few hardware SKUs that still use it, the Variax being one of them. I'm nearly certain that instead of trying to update Monkey to 64-bit, that what Line 6 is going to do is going to make it so Line 6 Updater supports the Variax. I mean the thing with this Catalina thing is that is was entirely a decision that Apple made that caused the issue. Apple dropped 32-bit entirely with Catalina, so it's puts the burden on other companies to react. Say what you want about Windows, but Windows 10 still support 32-bit software. I have a kb37 and the driver still works with Catalina. I always thought that Line6 is a good choice for the support too, not only for the quality of the products. If Line6 stops giving support, you might as well buy products of other brands. There is not difference..Very simple... Also: I understand the reasons of Apple. I don't understand the reasons of Line6 to end the support. Quote Link to comment Share on other sites More sharing options...
aneudys23 Posted August 7, 2020 Share Posted August 7, 2020 On 4/22/2020 at 9:13 AM, ADobie said: Finally I have my Pod X3 Live working on Catalina :) Uninstall exisiting driver using the Line 6 Driver Uninstaller app, then: Launch the Terminal application and type the following commands at the prompt: sudo pkgutil --forget com.line6.driver.xtaudio.package sudo pkgutil --forget com.line6.driver.xtmidi.package Then Reboot mac Disconnect the X3 live (I think this may be crucial as I went through the process without doing this and it did not work) Install the latest driver (7.6.8) Reboot mac Opened the driver config screen via system preferences Reconnected the X3 and there it is. Can now use Garage Band etc. This one worked!!! Thanks so much!!! Quote Link to comment Share on other sites More sharing options...
FinnKinsella Posted October 8, 2020 Share Posted October 8, 2020 On 7/11/2020 at 12:08 AM, pcosmo said: I had this problem, the issue wasn't that the Mac security was not allowing the drivers to be loaded. To fix this: https://line6.com/support/page/kb/recording/computer-audio-set-up-and-troubleshooting/macos-high-sierra-1013mojave-1014catalina-1015-driver-installation-change-r879/ This was the same problem for me as well Quote Link to comment Share on other sites More sharing options...
davereynaudsound Posted August 24, 2021 Share Posted August 24, 2021 Hi There, Found this thread as I have just acquired a Pod HD Pro. I am running a Mac Pro with Catalina. I have downloaded and run the installers for the latest drivers and Pod HD Pro Edit software that is available on the download section of the site. Ive also downloaded and attempted to run Line 6 Monkey. I have 2 issues. i) Line 6 Monkey does not run. ii) The POD HD Pro Edit Software program opens but then says it can't see my connected HD Pro. It is currently connect to my audio interface via 2 x balance XLR inputs and a USB cable. I am assuming this should have been enough connectivity for the software to recognise the hardware, but alas it seems not. Some people on this thread are saying you don't need Line 6 Monkey to download all the necessary files, however, even without Monkey (which itself seems STILL to be without a Catalina compatible update), I get a message saying the software does not "see" a connected Pod HD Pro. Any help / solution would be greatly appreciated as I really need to get this thing up and running for an impending project. Thanks to all who see this. Kind regards, Dave. Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 25, 2021 Share Posted August 25, 2021 6 hours ago, davereynaudsound said: Hi There, Found this thread as I have just acquired a Pod HD Pro. I am running a Mac Pro with Catalina. I have downloaded and run the installers for the latest drivers and Pod HD Pro Edit software that is available on the download section of the site. Ive also downloaded and attempted to run Line 6 Monkey. I have 2 issues. i) Line 6 Monkey does not run. ii) The POD HD Pro Edit Software program opens but then says it can't see my connected HD Pro. It is currently connect to my audio interface via 2 x balance XLR inputs and a USB cable. I am assuming this should have been enough connectivity for the software to recognise the hardware, but alas it seems not. Some people on this thread are saying you don't need Line 6 Monkey to download all the necessary files, however, even without Monkey (which itself seems STILL to be without a Catalina compatible update), I get a message saying the software does not "see" a connected Pod HD Pro. Any help / solution would be greatly appreciated as I really need to get this thing up and running for an impending project. Thanks to all who see this. Kind regards, Dave. Monkey won't run on Catalina, as it's a 32-bit application, and MacOS no longer supports 32-bit software. POD HD Pro should still work, though, and it should recognize the POD. Just to clarify, though, do you have the POD connected directly to your computer via USB? Quote Link to comment Share on other sites More sharing options...
gutoobarreto Posted February 22, 2024 Share Posted February 22, 2024 Here we are, 2024. POD HD500X is a huge multieffects but we don`t get to use in a MacBook Air M1, for exemple. Line 6 please give to us an alternative system to use or update the Monkey version to 64bit. Quote Link to comment Share on other sites More sharing options...
